how much compression is lost by flycutting
Subscribe
Oct 1, 2009 | 10:52 AM
i was wondering how much compression is lost due to flycutting 0.100 on intake and exhaust.
Reply 0
Oct 1, 2009 | 12:38 PM
It's not enough to worry about. You lose maybe 1.5 - 2 cc's, if that. Maybe .1-.2 loss.
Reply 0
Oct 1, 2009 | 01:00 PM
Like said, not much to be too concerned about PTV clearance is more important.
Reply 0
Oct 1, 2009 | 01:09 PM
Quote: PTV clearance is more important.
+1
You will loose a lot more compression when Mr Valve says hello to Mr Piston.
I would not worry about the lost compression. Cut a deaper pocket, mill the head more and it should even out.
Reply 0
Oct 1, 2009 | 04:51 PM
On a stock LS1 short-block with 243 (64cc) heads, by cutting a 2cc valve relief you stand to drop about .3 on your static compression. That's enough to plan for, IMO! While you've got it apart, mill the heads down a bit to get some compression back out of her, and make sure to cut enough to compensate!
Reply 0
Oct 1, 2009 | 05:50 PM
I seem to recall reading an .080" deep intake notch will be about 1cc.
This of course varies on how large of diameter cut you are making too. Cutting a 2.125" dia notch for an intake valve will obviously remove more material than cutting for a 1.6" exhaust valve.
Since you are cutting both .100" deep, -2cc would be a reasonable estimate.
When I cut mine, I planned on a 2cc loss for compression calculation purposes. When I got to actually cutting, and checking p/v, it turned out I didn't need to cut for the exhaust, and didn't. So my 11.5 compression goal suddenly became 11.67.
Which has not been a problem.
Reply 0
Oct 2, 2009 | 11:13 AM
sounds good i did mill the head .025 and used cometic .040 gaskets i had just been wondering what my compression ratio was approx i figured it would be arround 11:1. i have been tring to run down what my power loss down low is coming from. car has super slow take off not sure if i need a bigger stall, currently vig3200, i figured raising the compression would yeild more tq for take off not loose some.guess i need to mess with tune first.
Reply 0
Subscribe
