coolent temp sensor problem
Old Oct 1, 2009 | 02:34 PM
kirkjames90's Avatar
Default coolent temp sensor problem
ok i replaced my temp sensor with a new one and it worked great for about 2 months. now ill be driving and the car will sometimes die at idle then it wont start up for a few times. today while i was driving the temp went to 0 as i was pulling onto my street the temp went back to normal and the car acted fine again. idk what to do i replaced the sensor with autozone one idk if that could be why maby i need to dealership one? thx
Old Oct 1, 2009 | 03:04 PM
fast83z28's Avatar
It sounds more like you have a bad connection rather than a bad sensor. Check the sensor connector for bent pins or backed out pins and check the wire for abrasions.
Old Oct 1, 2009 | 04:56 PM
the pins look fine the front of the wire does to but i cant see most of it because its all wrapped up
Old Oct 1, 2009 | 07:02 PM
LargeOrangeFont's Avatar
good info!!
Old Oct 3, 2009 | 12:10 AM
ok i started the car and wiggled the wire that goes into the male connector and when i do this the car shuts off! i did this 3 times and it shut off all three times idk how you would replace this connector?
Old Oct 3, 2009 | 04:24 PM
anyone know where to get this connector that goes into the coolent temp sensor
Old Oct 4, 2009 | 09:56 AM
shoemike's Avatar
Connector Kits
I believe the connector is "pull to seat" get the pins too.
Old Oct 4, 2009 | 04:40 PM
ok the old connector had wires showing that kept touching i taped them up and now the temp gauge will not move at all it just stays at 0 i check the codes and it says it has a voltage problem
