cheap heads??
27 arp crank bolt
120 heads
228 arp bolts/headgaskets/ls2 chain
225 pushrods/valvesprings
$960 total. I'm pretty sure that's everything. You could save about $125 by using stock GM headbolts, or depending on your year model car put the money towards an oil pump. My car is a low mileage 2002, so that's why I'm reusing the stock one.
And like I said earlier, TSP had some $300 cams, so save another $60.
But, even if you found some ~$400 heads, used GM headbolts and crank bolt, and got a $300 TSP cam, it would still come in right about $1000.
I've seen good used cams from sellers on here going for ~$200!
https://ls1tech.com/forums/sponsor-s...wout-sale.html
I don't know if your car is an automatic or not? If automatic, spend the money on a new torque converter and worry about motor mods later.
Yes, GM crank bolts are TTY and only about $5. An ARP crank bolt is $26.
ARP bolts are stronger and reusable, but GM bolts are fine on a head/cam swap if you want to save money.
$30 for a set of a GM head bolts from patriot performance
$6 GM crank bolt Scoggin or whoever
$300-500 for 243, 799 heads
$300-400 cam
$150 PAC 1518 springs from scoggin
Now get all the other misc stuff, comp locators, locks, retainers, valve seals.
Suggested cam size for good daily driver setup: 224ish cam on xfi lobes 110-112 LSA. 400-415rwhp
Street / strip weekend warrior: 230ish cam 111 LSA. 415-430rwhp
Race only, high stall, gears supporting mods: 236ish + on xer, xfi, lsl lobes 110-112 LSA streetsweeper (good grind), thunder raptor cam or custom. 420-450rwhp
$300-400 cam
man i paid a good bit more for my 1518's than that
