Replacing My Head Gasket: A Noob Love Story (Please Help!)
#41
Im not 100% sure about the cars but if the PS cooler is in the radiator, your gonna need a new radiator. Its common with the trans coolers on autos, if they go out your in for a rad and trans, obviously this isnt a trans but it would look like your gonna need PS cooler and pump and a rad. Sucks man but it looks like it
also you said your oil was never milky or real liquidy?
#42
I'm about 99% sure it's the PS Cooler too, based on the info on this thread and other places, and just by seeing where the PS Cooler is, it's very likely...but...I'm a little paranoid. I'm taking the cooler to a shop to see if they can push 1200-1300psi of air through the PS Fluid nozzles to see if maybe they can find a crack in it that would let it seep into the coolant.
The other 1% of me says it still could be engine oil and a bad gasket somewhere. Based on spark plugs though, it's the 1, 5, 7, and 8 plugs that had some oil on the threads and the rest were dry. That plus, it's not as fast as the coolant, but I am consuming a lot of oil. In the course of 2.5 months/2500 mi, I'd pour 7 quarts of oil and when I drain it, I'd end up with only 3-3.5 quarts.
Time is starting to be a factor, so I don't know if I'll have time to go as far as the head gasket...but QUESTION: Can you replace valve seals with the engine still in the bay? ...or are there stories of the valves dropping into the cylinder or losing the clips to keep the spring down?
#43
Forget about the plugs. They were in there for WAY too long for you to get a judge of how the engine is running.
For the oil consumption, look at the PCV valve. A defective one will draw in more air than needed and that is where the oil goes in the majority of our cars.
If the PS Cooler is bad, might as well buy a new radiator too. That goop is almost impossible to get out and will just screw up the new parts.
#44
Also, since I've already gotten this far just do the compression test, I was wondering...how the hell do you actually do this thing? I guess my gauge is your standard one (this isn't mine, but it looks just like it):
http://www.summitracing.com/parts/SU...7/?image=large
Unless I'm doing this wrong (high possibility), I put the plug in the hole where the spark plug was, and I need to torque it, right? THEN I have to try to thread the hose in there? I couldn't even do it for the #3 plug hole, I'm sure I won't be able to do it for #8 or 7. If I have the hose already threaded into the plug I'm able to barely hand spin it into the hole (atleast with #3), but I imagine you'd have to tighten it much harder than that, right? What am I missing?
#46
#48
Oh...lol...sorry...i was looking at just the most recent post.
I meant in terms of selling. It's been in an accident...fixed...and then there's a ton of "city parking dings/dents" too, and the Bluebook on it was only like 5k in "Excellent" condition, so I figured it wasn't worth all that much to sell. It was worth much more sentimentally than it was on the market.... which is what gave me the idea of working on it myself.
#50
#51
YESSSSSSSSSSSS!!! Thank you thank you!! I'm being very honest here...that was the answer I was looking for! (as you can tell, I'm just looking for any excuse to say "ignorance is bliss")
I'll check that tonight! Thanks again!
OR just bend the hose, im sure if it is new, it will be stiff, but it will bend. Then you can thread it into the attachment and quick connect the gauge on.
#52
Or just put a quick disconnect fitting on the end of the spark plug fittings and put one on the end of the hose. I am sure that would probably be easier than what I mentioned above.
#53
Just ordered some NGK TR55IX plugs and msd superconductors! Do those plugs need to be gapped, and if so, what should they be gapped at? I'm seeing 2 different suggestions around the forum for .050 and .060. My car is mostly
stock, and just may have some boltons in the near future,
Also, For the time being, I wanted to just bypass that PS cooler altogether. So I'm just gonna get a replacement hose that goes from the radiator straight to the engine, which I don't suspect to be a problem, but then, I was thinking of just taking the return line from the power steering gear that was going to the cooler straight to the reservoir. With this being a high pressure system and all, do you foresee any problems with that since I'm cutting the distance by about half?
#54
Given the circumstances along with all the responses, I was pretty convinced that it was the PS Cooler, but I had to test anyway. I went over to my buddy's house and his dad had a 100Psi air compressor. We put balloons on both sides of the PS Cooler, where the coolant would be flowing through, and then blew air into one of the PS fluid nozzles while covering the other one with his thumb, and sure enough, the balloons started to inflate!
Just wanted to confirm the diagnosis for everyone.
#55
#56
No, I had a friend come over and check that once I got the diagnosis from the mechanic that the head gasket was leaking. That's a common symptom of a leaking head gasket though. In the end, all my concerns were due to the Power Steering cooler leaking, which caused the milky stuff in the radiator.
#59
