valves not seating, cam install
I am reinstalling the rocker arms and have torqued them too 22 ft/lbs, than rolled the motor over 180* and rechecked torque values.
I am noticing that some of the valves are not, or rather do not seem to be, fully closing. For example, the #2 intake valve opens fine and closes fine where I can just barely wiggle the rocker. The #2 exhaust valve however is noticeably compressed when it should be closed and is never wiggly.
I have rolled the motor over multiple times and hear/feel no valves hitting pistons. right now the spark plugs are out of the motor
So, could some of the lifters be stuck? or still have oil in them? I am really confused here
any help would be great!
thanks, Matt
Here is the correct GM procedure:
However, I did miss one key point in the OP's post. The rocker can't be wiggled so the valve spring is still putting a force on it. If the valve were bent, the rocker would be loose so the valve should be OK. I modified my post.
