zo6 cam in 5.3 pickup
you need the ls6 valvesprings which are about $50 you also need the longer pushrods as the base circle for the ls6 cam is smaller by .5. you can get away with a stock tune for awhile.
You'll need springs. A tune is optional but I'd recommend it.
BTW, if you are a heavy full sized truck and like torque, the LS6 cam has poor low end torque and will be a dog below 3000rpms. It will move pretty well in the upper rpms though. Tons of info in the truck forum.
http://www.performancetrucks.net/for...d.php?t=411641
