Stupid question about installing rockers
On pre LSX GM engines whenever I installed rockers on a hydrolic lifter motor I would put the engine in the #1 firing position and tourge 1/2 the rockers down while spinning the pushrod with my fingers until the pushrod wouldnt turn and then go about 3/4 more of a turn on the rocker nut to set the lash. Then I would turn the engine to the #6 firing position and repeat the last steps on the remaining 8 rockers.
Im getting ready to pull the heads on my LS1 and I read the torque spec for rocker nuts are 22 ft/lbs
I did a search to find that the LSX rockers sit in rocker stands.
Do the stock rockers nest in the rocker stands at a predetermined height where you can simply tourque them all down in one shot no matter what position the crank would be in? Cause that would be dope.
Jon
