Cheap Stroker?
Old Oct 22, 2009 | 10:53 PM
deuce4935's Avatar
Default Cheap Stroker?
Hey guys is it possible to have the 4.00" ls7 crank modified to fit a stock 5.3 block without changing the rods and pistons? I was reading the Dec 09' issue of car craft where they took a oldschool 350 block and added a 4.00" crank to it instead of the tried and true 383 setup, and what they came up with was a torque monster sbc. So my curiosity has me thinking about the torn down 5.3 I have on the stand...... Can anyone tell me if this same route can be taken with the 5.3?
Old Oct 22, 2009 | 11:07 PM
G Engines's Avatar
no you need to change at least the pistons to match the 4.00 stroke and if your going to try make good hp i recommend changing the rods also.
Old Oct 23, 2009 | 02:51 PM
vipvegas's Avatar
Its all in h/c/i chosen also..
Old Oct 23, 2009 | 07:16 PM
deuce4935's Avatar
What exactly does h/c/i stand for?
Old Oct 23, 2009 | 07:33 PM
vipvegas's Avatar
Heads cam Intake
Old Oct 23, 2009 | 07:36 PM
Gaunt's Avatar
Stands for no longer cheap :/
Old Oct 23, 2009 | 07:40 PM
vipvegas's Avatar
exactly you leave it stock and just do a 4 inch stroker kit. It will just be a torquey truck style motor.. Its all in the heads cam and intake to achieve the rest
Old Oct 23, 2009 | 07:41 PM
87gnx's Avatar
Don't go the cheap route, you'll regret it. Save up, spend the bux it'll be worth it in the long run. $.02
