Day 1 of 224/228 cam, 96mm TB, heads, 92mm FAST swap
Old 11-08-2009 | 08:03 AM
  #61
firefighter813x's Avatar
My car makes a ticking noise too. I just assumed it was a result from the Fast 90/90 combo swap. I've read it was a common thing, I'll just go with it. lol
Old 11-08-2009 | 08:29 AM
  #62
Hardtop's Avatar
Good luck. I don't know many people that have had good luck with the 1.85 rockers. Sounds like the stock rockers are going to be better for you.
Old 11-18-2009 | 08:36 AM
  #63
Intercooler2's Avatar
Dyno'd again yesterday with the arms changed. See Saturday what difference it makes at the track!
Attached Thumbnails Day 1 of 224/228 cam, 96mm TB, heads, 92mm FAST swap-scanimage001.jpg
Old 11-18-2009 | 06:54 PM
  #64
Hardtop's Avatar
The power is a little better, but the graph looks a lot better. Good luck.
Old 11-19-2009 | 07:41 AM
  #65
So the big question is will it pick up .2/2 MPH. If it goes 11.20@120 I think mission is accomplished with this combo. Will the better curves and useable RPM pick it up that much?
Old 11-19-2009 | 02:30 PM
  #66
thewholefnshow1's Avatar
Originally Posted by Intercooler2
I get a little sewing machine noise so I am ordering longer pushrods then it will be 100%.
My heads:
64cc
I would have ran it today but the track was just too packed. Next Saturday I am going again. I think it will go 11.20@120 but who knows.
You can take this for what it's worth. But if the longer pushrods doesn't quite it down then try a shorter pushrod. Long story in a short verison. At my H/C/I swap. My tuner put in 7.4 and it was pretty noticeable hearing it, he said if it don't get any quieter after I put some miles on it bring it back. When I took it back he put in some 7.35 and it quieted it down a bit. These are just noisy motors from what I read. The way I look at it for the power they put out, the hell with the sewing machine sound. When your wide open all you hear is exhaust. But every car is different and so is the setup.
Old 11-19-2009 | 03:30 PM
  #67
nocooler's Avatar
2mph shouldn't be an issue!
Looks like your up almost 40hp from the dip in the previous graph. Your hp is almost flat from 5500rpm on. Nice curve.
Old 11-19-2009 | 03:56 PM
  #68
jimmypop13's Avatar
Did you ever take the breather off? You could be missing some power there. I had a hole in my pcv system which is similar to having a breather. Once I got new pcv lines and ran them, my idle became rock solid, and the car ran better at part throttle. I didn't do back to back dynos but I've heard plenty of people say your losing power if your pcv isn't sealed properly
Old 11-19-2009 | 05:41 PM
  #69
No and maybe I should try that one run to see. It was tuned on the dyno as-is with breather.
Old 12-18-2009 | 08:02 AM
  #70
gnasty1521's Avatar
did you ever run it?
Old 12-18-2009 | 10:34 AM
  #71
01ssreda4's Avatar
Holy Chit..................Guessing at pushrod length can be expensive in the long run....and I aint talking about all the sets of pushrods you bought and tried.
Old 12-18-2009 | 10:51 AM
  #72
Slvr00Bird's Avatar
+1... just measure and do it once..
Old 12-18-2009 | 01:42 PM
  #73
Yea best was the 11.41@119 in the sig
Old 12-19-2009 | 12:34 AM
  #74
gnasty1521's Avatar
Wow that is a great time! And you were worried about 2 mph?????
Old 12-19-2009 | 09:43 AM
  #75
Maybe the lift is killing me. Just figured this combo change would have netted 11.20@121. I was thinking .5/6 MPH gain but I got .4/4 MPH gain. Hoping to fit the Raptor but 10's may just not be possible at this weight NA
Old 12-19-2009 | 11:17 AM
  #76
gnasty1521's Avatar
Is it your DD?
Old 12-19-2009 | 11:24 PM
  #77
Nope... got a Honda for that and a bike. But when it is nice out I do drive it often and every so often 100 plus mile trips.
It's pretty docile and works. Just I know I am down on lift so the cam is a tweak that may net me some. Only motor **** I have really.
I may spray it at some point next year after I do a fuel pump. I'm thinking 150 shot.
Old 12-30-2009 | 08:03 PM
  #78
Monte4ever's Avatar
Having a hole in your PCV system is not like having a breather. This would create a vaccum leak that would mess-up your idle. There's a reason why you cap the plug when you remove your PCV valve/system (bad idea) on the TB. If you don't you will have a huge vaccum leak. IMO running a breather is good because it allows fresh air to enter the crank case and helps with circulation.
Old 01-15-2010 | 01:02 AM
  #79
Bjorne043's Avatar
Pardon me for being the idiot of the group, but the part about using stock rockers is interesting to me. Does that make a difference if its an A4 or an M6? Just looking for answers because I'm doing this mod myself in about a month.
Old 01-15-2010 | 04:42 AM
  #80
It doesn't matter A4 or M6. What mod are you doing? You can use whatever ratio you want if you put the right spring. In my case I would have needed an even more aggressive spring to handle the weight if I had kept the 1.85's.
Quick Reply: Day 1 of 224/228 cam, 96mm TB, heads, 92mm FAST swap
