Found the rest of #5 in the intake.
Old Oct 26, 2009 | 02:37 PM
T-56SLPSS's Avatar
Default Found the rest of #5 in the intake.
went out to start my car the other day, heard a loud pop and it died, started it back up and shot antifreeze out the tail pipes. Finished engine removal today. after hoping for a blown head gasket i found a hole in the side of #5.got a couple questions. anyone had problems with the 2 prong bosch plugs comming apart? and now looking for ideas for rebuild under budget. anyone has any ideas i would appreciate the help.. Thanks
Old Oct 26, 2009 | 02:51 PM
TooLateVTEC's Avatar
As long as you dont plan on spraying, I would just buy a stock rebuild kit.
I would upgrade the rod bolts while you have the motor out though.
Old Oct 26, 2009 | 06:08 PM
T-56SLPSS's Avatar
Iknow a guy that says he can get me a 6.0 or 5.3 for cheap. If I did this I would cam it and maybe change the heads Would they bolt up? Not sure what's interchangable
Old Oct 28, 2009 | 12:44 AM
LSX Truck's Avatar
damn, that's gota hurt! first engine I had, cylinder 1 ended up in cylinder 5!!
Old Oct 28, 2009 | 04:39 AM
dangerjakeray's Avatar
i do believe that almost all ls1 parts will fit on a 5.3 or 6.0, not sure which parts wont.
the heads definately will. ive seen a 5.3 with a z06 cam in it.
also if this is guna be on the cheap, check ebay for the 5.3, they always have junkyards selling alot of them.
Old Oct 28, 2009 | 09:14 AM
sman's Avatar
I have a 5.3 in my car, it all bolts up except the alternator, you have to drill and tap 1 hole in the block.
Old Oct 28, 2009 | 12:45 PM
T-56SLPSS's Avatar
thats good news. how about the 8.1 or the 6.5 those are two other ideas.. i find out today about getting a 6.0. dont know if i should use the ls heads or the 6.0's but will have them ported throw a cam and i should be good to go
Old Oct 28, 2009 | 01:52 PM
DONAIMIAN's Avatar
The 8.1 isn't a genIII so you will have hell trying to drop one in. Not to mention the size of the motor in a small F-body engine bay.
Old Oct 28, 2009 | 02:06 PM
01ssreda4's Avatar
The 8.1 is heavy too. And it doesn't have the aftermarket support like Gen III motors do.
Old Oct 28, 2009 | 04:05 PM
T-56SLPSS's Avatar
well would a lq4 bolt up to the t-56? im thinking Lq4 with L92 heads with the tr230 or just have my block fixed ls6 heads with the 230? which would be better?
Old Oct 28, 2009 | 04:16 PM
T-56SLPSS's Avatar
or lq4 l92 ms3
Old Oct 30, 2009 | 09:05 AM
techrunner's Avatar
an lq4 is a bigger iron ls1, transmissions are the same as long as its i think an 01+ block, before that there was a different length crank.
Old Oct 31, 2009 | 09:00 AM
cam75w/ls1's Avatar
I put a new motor in a Maxima about two years ago from a Bosch plug coming apart. Just like yours.
Old Oct 31, 2009 | 04:51 PM
FasTimeSS's Avatar
Make up you GOD DAMN MIND!!!!
J/K
Sorry to hear about the motor.
Go BIG or Go Home!
