Need HELP! please please!!g5x4
Old Oct 26, 2009 | 05:57 PM
SSdimension's Avatar
Unhappy Need HELP! please please!!g5x4
I got Ls6 heads stock, a g5x4 cam, and stock pistons. The heads are not milled, ported, or deck'd. They are stock. The pushrods I bought from Trick Flow on the Tick Performance website and the pushrods are harden. The spec of the pushrods are 7.400 and .080. But the piston is kissing the valve. The springs on the Ls6 heads are aftermarket handling up to .650 lift. Can someone diagnose the problem???Thank in advance and your response will be GREATLY appriciated. Antonio.
Old Oct 27, 2009 | 06:51 AM
teke184's Avatar
isn't that the cam that lgm lists as "secret"?
if so...how the hell are we supposed to know anything about diagnosing it.
Old Oct 27, 2009 | 12:04 PM
Unhappy
I know and it sucks. I hate to put the Ls1 cam on, I have not driven my car in 9 months and it will be sad to see it only with bolt ons. Does anybody out there have a g5x4 cam. If so what size pushrod? Thanks in advance. Antonio.
Old Oct 27, 2009 | 12:34 PM
tim99ws6's Avatar
You need to call LG
Old Oct 27, 2009 | 12:38 PM
RSbeast's Avatar
Possibly how it is degreed?
Old Oct 27, 2009 | 01:08 PM
tim99ws6's Avatar
a cam that size with the cam degree off by one tooth definitely would cause problems.
Old Oct 27, 2009 | 02:50 PM
Originally Posted by tim99ws6
You need to call LG
Got a number for LG Motorsports or where I can find it? From a logical guess its a .609/.612 or something like that. Some g5x4 owners said its almost identical to the t rex cam.
Old Oct 27, 2009 | 02:53 PM
tim99ws6's Avatar
If it's similiar to Trex, it's considerably larger than .609/.612, and i'd assume its the duration that is busting your chops as much as the lift!
LG Motorsports
http://www.lgmotorsports.com
Phone number: 972-429-1963
1211 S Highway 78
Wylie, TX 75098
Old Oct 27, 2009 | 02:57 PM
DCsLS1's Avatar
you might need to go back to the dot to dot part make sure they are perfectly straight up and down when you line them up and then turn it over by hand one time and make sure they line up again at the right point if it is off even a little it could cause this
Old Oct 27, 2009 | 02:59 PM
tim99ws6's Avatar
Yep...one tooth is a considerable amount of advance/retard on a cam that was already designed to BARELY fit dot-to-dot
Old Oct 27, 2009 | 04:16 PM
Called. Only problems it can be is the head gaskets clearance or to fly cut the pistons. Any suggestions???
Old Oct 27, 2009 | 04:31 PM
tim99ws6's Avatar
What head gasket did you use? You shouldn't need to flycut pistons on that dude. Did you talk to Louis@LG??
Old Oct 27, 2009 | 04:39 PM
JPH's Avatar
JPH
Its a 240/244 113 cam. It should clear, but just by slim margins aslong as everything else is stock! And how are you checking it? Soft spring method or what?
Old Oct 27, 2009 | 04:43 PM
txh0tb0i972's Avatar
you cant reuse head gaskets or bolts is the problem
Old Oct 27, 2009 | 05:18 PM
Minshall's Avatar
Ive got the same cam but im still using my LS1 heads. If the heads are milled, thinner head gasket or etc.. then youll run into the ptv issues. As long as your using stock head gaskets, re check the cam timing.
Old Oct 27, 2009 | 09:54 PM
How many LG stores in Texas. I dont know who I spoke to in the store in Wylie, TX.
Seeing it from one of the holes from the headers.
I know now..thnx
Heads are stock. Bought them from txhotboi972. Says they are stock and I believe they are. Gasket Brand is EnegineTech. The parts stores said it stock replacement.
If I order stock gaskets from all the parts stores will they all be the same size?
Old Oct 28, 2009 | 12:38 AM
LSX Truck's Avatar
great cam! make sure u have the accessories to go with it
Old Oct 28, 2009 | 08:34 AM
tim99ws6's Avatar
You need to go to GM, and get a set of "MLS" head gaskets. Just ask for head gaskets for a 2002 Camaro Z28 and they should sell them to you. Or buy them from a distributor/sponsor---> I prefer Speed Engineering.
Don't run crappy auto-parts stores version of head gaskets, and make sure you get a new set of bolts. They are stretch-to-yield. Once they are used once, they will never work again(as you already know now).
Old Oct 28, 2009 | 08:51 AM
Slow 346's Avatar
A stock replacement gasket from the parts store dosent necessarily mean its the same thickness as a stock GM one. Get a stock GM gasket to be safe.
Old Oct 29, 2009 | 02:36 PM
ws6_bandit's Avatar
I have g5x4 and stock heads. Installed mine dot to dot and no problems. PTVC is very close tho. Im pretty sure valve drop between ls1 and ls2/ls6 is pretty much the same. You must be off a tooth or you have the wrong head gasket.
