5.3 block
Old Oct 26, 2009 | 10:48 PM
kenracer's Avatar
Default 5.3 block
How large can you bore a 5.3 steel block and live?
Old Oct 27, 2009 | 01:10 AM
00MaroonZ28's Avatar
it's iron not steel, and it's not worth it when you can get a 6.0 liter block cheaper than it would cost to bore the 5.3 block
Old Oct 27, 2009 | 08:50 AM
5.3LJimmy's Avatar
It can be bored safely to 3.898-3.905(the same bore as an LS1 or 347 respectively). I've heard of people taking them further but I wouldn't recommend it.
Old Oct 27, 2009 | 11:53 AM
Johnnystock's Avatar
Get an LQ9, LQ4..6.0l is better.
Old Oct 27, 2009 | 11:59 AM
BlownChevySS's Avatar
I think the highest you can go with the lq9/4 block is 408 or maybe to 413 right?
Old Oct 27, 2009 | 02:20 PM
KCS's Avatar
KCS
Moderator
You can go higher displacement with an iron 6.0L, like 427ci, but bore wise ~4.060" is generally thought to be the limit.
Old Oct 27, 2009 | 02:35 PM
I was just talking about with the bore, not stroke, pistons, and deck clearances. But thanks for the insight.
Old Oct 27, 2009 | 03:13 PM
KCS's Avatar
KCS
Moderator
Huh?
408ci and 413ci are both with stroke though, same as 427ci. 370-375ci are with bore only though. All of that has to do with pistons.
Old Oct 27, 2009 | 03:22 PM
Huh?
Sorry. I was horribly misinformed then.
