Checking pushrod lenght
Old Nov 3, 2009 | 04:56 AM
vettenuts's Avatar
Originally Posted by 69LT1Bird
I don't know why you don't believe Shane, the procedure he uses works great. I checked mine with a pushrod checker (sucks getting your figures in there to turn it accurately) and then I used his method and came up with 7.370 for mine.
This is from Yella Terras Site by the way.
Do roller rockers need special push rods?
Usually no, with the exceptions being:
1. When screw-in studs and hardened guide plates are to be fitted (on engines not fitted with them originally). These need hardened pushrods.
2. When extremely heavy valve springs are fitted a more robust push rod than standard may be required.
What tappet settings do I use when fitting roller rockers?
Whether using Roller Rockers or standard rockers, the tappet settings remain the same as specified for your camshaft.
You missed my point. As I recall Yella Terra warns against tightening only one rocker of the pair and directs you to rotate the motor so each cylinder is on the firing TDC so the rocker pair can be tightened together because they share the same trunnion. Using the EO/IC method would require only one rocker of the pair be tightened which directly conflicts with the Yella Terra warning not to do so. As I stated, unless I misunderstand the recommendation in the above post, this would go against what Yells Terra is telling you to do for installation.
Old Nov 3, 2009 | 03:32 PM
vettenuts's Avatar
Pulled the instruction sheet from Yella Terra, here is the step:
Old Nov 3, 2009 | 07:56 PM
DeanJ's Avatar
Originally Posted by deelli
Thanks for all the responses. My setup is LS7 lifters, TSP Torquer v.2 232/234 .595/.598 112 cam, 799 heads milled 0.015, stock rockers, GM head gaskets. I've gone and made measurements and with pushrod checker I get 7.280, I've also used the torqueing method and I get about ~1 5/8 turn before reaching 22lbs torque using a 7.4 pushrod. Now if I'm understanding correctly using the torque method the 7.4's are ok? (1 1/4 to 1 3/4 turns) and with the checker looking for a pushrod between .050 to .080 preload would mean I need a 7.350 pushrod. I'm not clear as to what to do right now.
Lets get back on topic, and help this guy with his question.
Grip pushrod between fingertips and turn, then slowly tighten rocker bolt. When you start to feel resistance on the pushrod, count turns till fully torqued. If you had 1 5/8 turns on the bolt with 7.4" pushrods, they will be fine. Still in 1 1/4 to 1 3/4 turn range. Hope this helps, Dean
edit: The lifter must be on the base circle of the cam. You don't have shaft rockers do you?
Old Nov 4, 2009 | 04:40 AM
vettenuts's Avatar
Looks to me that your measured value is correct. If you check with the 1-5/8 turns (assuming that the bolt hasn't been turned past rocker bottoming), the preload I come up with is 0.127" with the 7.400" pushrod. If you reduce the pushrod by 0.050" to a 7.350" then the preload should come down to 0.077" which is in the range you are looking for. I would favor your direct measurement with the adjustable pushrod.
Old Nov 4, 2009 | 07:44 PM
DeanJ's Avatar
I thought that when the bolt was fully torqued he had a total of 1 5/8 turns from when the pushrod contacted the rocker. Dean
Old Nov 5, 2009 | 04:43 AM
vettenuts's Avatar
The only time lifter preload is developed is between zero lash and when the rocker bottoms on the rocker stand. Any further bolt rotation used to achieve the final torque value is loading the bolt and the joint, which won't further change the lifter preload. For example, if you tighten the bolt to 22 lb-ft or 50 lb-ft, it will not change the preload any significant amount but the bolt rotation will change. There are a lot of variables in this method, the adjustable pushrod is much more accurate if done correctly.
The bolt rotation method works well on stud mounted rockers because the rocker doesn't bottom against anything, but on shaft mounted rockers you should use a dial indicator rather then bolt rotation and torque.
Old May 18, 2012 | 02:37 PM
468BIGBLOCK's Avatar
i like this.
