oil in exhaust?
Old Nov 4, 2009 | 09:09 AM
Parasoth's Avatar
Correct, per WhiteRhinos response, you will only need sealant if they are ported, as the rocker arm holes are apparently touched/opened up when doing the port.
Stock heads will still let oil down the rocker bolt hole, but it will not drop into the head as the hole is untouched and still closed.
Old Nov 4, 2009 | 09:21 AM
jwilsonf's Avatar
any one had any smokimg issues from changing oil? i put some cheap oreilly oil n it to get it running and was goin change back to mobil one after I got cam broke in andbugs workrd out .. could this cause smoke?
