Help! Need setup adivce! Dont want to wast money!
The Car:
Stock 2002 Camaro Z28 with only 30k Miles. SLP Lid and Loudmouth.
Goal:
To have a daily driver setup that isn't crazy loud/obnoxious but is absolutely nasty all around. No more than or right around naturally aspirated 500 rwhp.
Option 1- Send to lingenfelter. But its like 15k and that only gets me engine work.
Option 2- Find another performance shop to Due my upgrades...This is the List from what I have seen and read here in LS1 Tech
Engine:
Ported Heads to Match Cam.
Comp Cam w/ Underdrive pulley and all springs+rods
LSX FAST intake 92mm
Throttle Body to Match
Kooks Headers w/ Y pipe
Magna flow / Hooker Aerochamber w/ Catback
Tune and dyno
Transmission:
Stock T56 with upgrades to strengthen weak links.
Spec 2 Clutch
Drivetrain:
Moser 9"
Driveshaft to match rear end with 4.11s or 3.73
Suspension:
Bilstein Shocks
Subframe connectors
Front/Rear Sway bars
Fuel: Stand Alone Fuel Management System
Anything I miss or need changed to my plan?? Is this a good all around setup? Recommendations? Ive been to VA Speed but I haven't talked with anyone who gives me a warm and fuzzy yet. Dont seem price friendly either. Please help.
Goal:
Engine:
Tune and dyno
Transmission:
Spec 2 Clutch
Drivetrain:
Moser 9"
Suspension:
Bilstein Shocks
Subframe connectors
The Car:
Goal:
Engine:
Tune and dyno
Transmission:
Spec 2 Clutch
Drivetrain:
Moser 9"
Suspension:
Bilstein Shocks
Subframe connectors
Goal:
Engine:
Tune and dyno
Transmission:
Spec 2 Clutch
Drivetrain:
Moser 9"
Suspension:
Bilstein Shocks
Subframe connectors
You could make it a 383ci stroker and easily make 500+ RWHP.
You don't need to "waste" money on a stand alone fuel management system. Save that money till you build a 1000+ RWHP turbo build. All you need is your stock PCM, it can do it all. You're talking about a very mild build.
I'd scratch the Moser 9", not needed for just a street car. If you're gonna go to the track and dump the clutch at 5,000 rpm with drag radials...then yes.
If you do all that stuff, stay stock cubes, basically a good head/ aggressive cam kit with those extras you should be damn near 500 RWHP with that M6, maybe more.....it'll be a blast to drive. And for $15,000 you can do your car, then hook one of your friends up with the same stuff. Don;t get ripped off by anyone. Research everything.
VA Speed is very good shop, BTW.
suspension you missed LCA'S lower control arms, lots of web people use relocation brackets for the lca's, also panhard bar. im sure plenty of sponcors would like your business, dont be afraid to negotiate a package deal. have you considered a 402 short block with heads and medium cam? just my 2 cents
I'm surprised no one didn't say this but if you don't want it to be crazy loud/obnoxious. You need to get rid of that Loudmouth especially when you slap Long Tubes on it. It's going to be very loud and turn into the Raspy and dronemouth. Come on guys I can't believe yall didn't catch that. But I would consider getting bigger cube motor with a medium cam as said above. There's no better replacement then cubic inch displacement. Did I get that right you guys? lol Good Luck I crack myself up, sometimes.
haha, thanks man but i forgot to mention that I am DEF getting rid of it. I know its going to be obnoxious cuz it alomst is already. I am trying to find the quietest exhaust there is. Any opinion?
i really like my hooker CB, has a nice rumble and is very tame, but WOT it really wakes up. ive been told by everyone that my car sounds amazing, i think its too quiet but a cam will change that
