View Poll Results: What do you consider to be an acceptable valvespring life?
5-10K
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
3
3.19%
10-15K
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
15
15.96%
15-20K
![](https://ls1tech.com/forums/images/polls/bar4-l.gif)
![](https://ls1tech.com/forums/images/polls/bar4.gif)
![](https://ls1tech.com/forums/images/polls/bar4-r.gif)
25
26.60%
25-30K
![](https://ls1tech.com/forums/images/polls/bar5-l.gif)
![](https://ls1tech.com/forums/images/polls/bar5.gif)
![](https://ls1tech.com/forums/images/polls/bar5-r.gif)
25
26.60%
35-40K
![](https://ls1tech.com/forums/images/polls/bar6-l.gif)
![](https://ls1tech.com/forums/images/polls/bar6.gif)
![](https://ls1tech.com/forums/images/polls/bar6-r.gif)
7
7.45%
40-50K
![](https://ls1tech.com/forums/images/polls/bar1-l.gif)
![](https://ls1tech.com/forums/images/polls/bar1.gif)
![](https://ls1tech.com/forums/images/polls/bar1-r.gif)
8
8.51%
50-75K
4
4.26%
75-100K
4
4.26%
100K+
3
3.19%
Voters: 94. You may not vote on this poll
What is an acceptable valvespring life to YOU?
For me it's more of I don't want to deal with it more than once a year period. I usually drive ~20,000 miles a year so say 25,000 miles min. My 99 T/A only saw 6,000 miles last year so at that rate valve springs every ~2-3 years seems very reasonable to me for a decent heads and cam car.
Originally Posted by RPM WS6
Stroker or all bore motors both present the oppertunity for internal items to wear and/or break sooner than a 346 motor. So even though you might be getting the same power with a smaller cam and longer valvespring life, you are facing new potential issues with stroker and/or bored motors over the stock cube motor. Bascially, there is no easy way out. If you are going to mod for more power, something is gonna give sooner than if it were stock.
Originally Posted by Cal
I agree . . . Besides the reasons already mentioned, any time you increase the stroke of a motor, piston speeds increase, and that increases cylinder wear and lowers the rpm the engine can turn before it throws a rod. And increasing the bore will make the block weaker and more prone to flex under stress. Having said that, the C5R 427's seem to be doing pretty well.
Thanks y'all - I knew all that, but considered them problems with easy solutions.
piston/rod angles? Don't go any bigger than 4.00 stroke
Dropped Sleeves? Don't buy an all bore engine for a few years, wait until they've sorted that issue out and let someone else be the guinea pig.
Increased piston speeds? Lower the redline, or keep it at 6000rpm. Or put it at 6500, but don't go there often.
Block more prone to flex under stress? Sounds like a non issue for a N/A application - and if you're on boost you're going to lift a cylinder head before you flex the block.
There may be reliability/longevity issues with stroker's and all bores, but you don't encouter them with a mild setup.
STF Veteran
Originally Posted by 99-LS1-SS
Explain to me how increasing the stroke increases the piston speed. To me it seems like increasing the stroke only increases the distance that the piston travels instead of the speed at which it travels.
Im gonna say 5 to 10k , that is what I hope for on my next set of valve springs, My last set of 02 ls6 springs did great for 400 miles LOL now I invested in some manley springs and ti Retainers . Im pretty hard on the car and I spray it so Id be happy with 5 to 10k.
I said 40 to 50K but I would be happy and cross my fingers for 40K.
I will be going with the TR230 cam with dual springs and Tit Rets. I know allot of people say that dual springs are over kill for a 575/563 lift cam..... but I want over kill so maybe I can get 40K
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
