Cam install on an A4 question
Old Feb 18, 2003 | 08:16 PM
ScreaminTA's Avatar
Default Cam install on an A4 question
I'm going to be installing heads/cam package on my 2000 A4 WS6 and I was wondering what techniques people have used to lock the flywheel while removing the crank pulley. Anyone use the flywheel locking tool or some other method?
Old Feb 18, 2003 | 08:22 PM
Dave Carney's Avatar
Default Re: Cam install on an A4 question
I used the tool, it works great but like all Kent Moore it costs 4 times what it should...
Old Feb 18, 2003 | 08:41 PM
ScreaminTA's Avatar
how much did it run ya?
Old Feb 18, 2003 | 09:06 PM
Cal's Avatar
Cal
Well if you don't want to spend a butt load of money on a tool you only use once, do it the old-fashioned way: Take the spark-plug wires off or unplug the ignition coils. Next get out your heavy-duty breaker bar socket wrench with one-inch drive and put it on the bolt with the handle braced against the ground on the DRIVER side of the pulley. Then go tap the starter switch. The bolt is now loose!!! <img border="0" alt="[evil]" title="" src="graemlins/gr_devil.gif" /> Serious, it works.
<small>[ February 18, 2003, 09:07 PM: Message edited by: Cal ]</small>
Old Feb 18, 2003 | 09:12 PM
ScreaminTA's Avatar
Sounds good... <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> Any other methods?
Old Feb 19, 2003 | 10:49 AM
Chad R's Avatar
I had a freind hold the flywheel with two screwdrivers, while I broke the bolt free. It wasn't easy, but it worked.
Old Feb 19, 2003 | 08:11 PM
Black Sunshine/ 00SS's Avatar
I use a crow bar in the flywheel hole, (take off the starter), and have a friend turn the crank bolt out while I hold it, or vice versa. Works every time.
Old Feb 19, 2003 | 09:01 PM
Dr. Jeckel's Avatar
Wedged the end of a wrench in one of the three holes and then used a very big breaker bar. Wrench got stuck...but it came unstuck after torqueing it back the other way a little bit. Don't know about the starter idea....seems a little harsh on your starter, especially if you want it to last. Just my opinion though.
Old Feb 19, 2003 | 10:01 PM
DERTY's Avatar
The Bull
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Black Sunshine/ 00SS:
<strong> I use a crow bar in the flywheel hole, (take off the starter), and have a friend turn the crank bolt out while I hold it, or vice versa. Works every time. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yup, works like a charm. Just make sure your friend is a little bigger than a smurf though. It takes a little bit of strength to snap that baby loose.
Old Feb 20, 2003 | 12:19 AM
Constrictor 98TA's Avatar
What about taking an air wrench capable of 250+ ftlbs and just putting it on the bolt and giving it one good shot? Would this work or would it be too harsh on the engine?
Old Feb 20, 2003 | 12:24 AM
mighty mex's Avatar
Haven you people heard of working smarter not harder. Get your impact gun, put it on reverse, squeeze the trigger, oh look the bolt just came off all the way. And take a look at that the motor is not hurt nor did it turn!!!!!
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Constrictor 98TA:
<strong> What about taking an air wrench capable of 250+ ftlbs and just putting it on the bolt and giving it one good shot? Would this work or would it be too harsh on the engine? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
Old Feb 20, 2003 | 09:02 AM
AFTICA's Avatar
I used the Cal method (above) of removal with the starter & the Chad R method (above) to re-install.No special tools & no starter removal.FWIW my 250ft-lb impact didn't move that bolt.
Old Feb 20, 2003 | 07:37 PM
ScreaminTA's Avatar
Thanks for all the input. I'll just put my little bro under the car and let him hold the crow bar in there. I'm about 220lb and lift weights constantly so I don't think it'll be a problem getting the bolt out.
Old Feb 21, 2003 | 08:01 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by mighty mex:
<strong> Haven you people heard of working smarter not harder. Get your impact gun, put it on reverse, squeeze the trigger, oh look the bolt just came off all the way. And take a look at that the motor is not hurt nor did it turn!!!!!
<strong> What about taking an air wrench capable of 250+ ftlbs and just putting it on the bolt and giving it one good shot? Would this work or would it be too harsh on the engine? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"></strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That bolt just laughed at my 250 ft lb impact wrench.
Old Feb 21, 2003 | 05:56 PM
99Z284MAC's Avatar
all i used to get it loose was a 1/2 drive air wrench, a puller an a log pry bar
Old Feb 22, 2003 | 12:05 AM
"Just make sure your friend is a little bigger than a smurf though."
I think you meet the qualifications for that one! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Feb 22, 2003 | 12:06 AM
Cal's Avatar
Cal
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by CustomTA:
<strong> Don't know about the starter idea....seems a little harsh on your starter, especially if you want it to last. Just my opinion though. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It doesn't hurt the starter; it pops it loose instantly without straining at all. This is the method used by Mr. Goodwrench! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<small>[ February 21, 2003, 12:08 PM: Message edited by: Cal ]</small>
