I have Know Idea????
Name is Josh
here is the story
got a 02 SS got a built ls1 with a D1SC on it running about 10psi. Last year i put the bolt that holds the damper on through the oil pan "long story".
Put on a oil pan and a new ati damper and last night i finally got every thing togather, cranked it up and it sounds like its only firing on 2 or 3 piston i mean it sounds rough! when i gave it some throttle it would only spin up to like 3000rpms. any ideas? bad gas, timing, blower belt to tight, what?????
Thanks
here is the story
Thanks
LS1Tech Premium Sponsor
Josh, do you have one of those handy little spark testers that you can get at Autozone for crazy cheap? You put it inline between the wire and plug, and it has a little light that will illuminate if/when it gets the shock from the coil. That could help narrow down the guess work as to which cylinders are firing and which are not.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
