head gasket
Old Nov 19, 2009 | 01:23 PM
Demonhawk01's Avatar
Default head gasket
alright i got a few questions and need some advice, after using the sites awsome search bar tht never lets me down i came up with nothing. so heres my question
i got a stock ls1 block that i am rebuilding, its stock bore and will b honed, if someone could inform me what head gasket to use that would be great. the motor will be around 11:1, and will get driven everyday and will prolly get the **** beat out of it everyday. i basically want the best bang for the buck. part numbers would be great too!
Old Nov 19, 2009 | 01:46 PM
Jon@Texas-Speed's Avatar
GM MLS head gasket will work great for you. Part # 12498544. I have plenty on the shelf! Give us a call. 806.866.0734
Jon
Old Nov 20, 2009 | 10:18 AM
texas speed, always up front w the customer service
Old Nov 21, 2009 | 11:14 AM
what if i wanna run somethin thinner than 51 thou?
Old Nov 22, 2009 | 01:20 AM
anyone?
Old Nov 22, 2009 | 12:18 PM
SOMbitch's Avatar
Cometic
Old Nov 22, 2009 | 12:22 PM
bigboykilroy's Avatar
+1 for GM MLS. Im running GM MLS on cut 243 heads to about 61cc. running about 11.1 no issues, but if you do want thinner then I agree get Cometic then.
Old Nov 24, 2009 | 12:24 AM
i hear cometic have been prone to sealing issues. or has that been in like fi apps?
Old Dec 4, 2009 | 02:39 AM
so i plan to run a 60cc head w a mls gasket, anyone wanna take a guess at what comp that will b?
Old Dec 4, 2009 | 09:26 AM
We typically hit the Cometics with some copper gasket spray on motors that have been run before to help them seal. We haven't had an issue with gaskets leaking when doing this.
My calculator shows your static compression at 11.24:1.
Jon
Old Dec 5, 2009 | 03:02 PM
Jon
that would be just about perfect right? im gonna be on 93 octane 94 once in a while, ive always heard about 11.3 is a safe max on 93
Old Dec 13, 2009 | 03:51 PM
357i's Avatar
Will these work on a '98 with the notches in the heads?
Jon
Old Dec 13, 2009 | 04:34 PM
02 BLK WS6's Avatar
Nope, won't work
Old Dec 13, 2009 | 05:25 PM
357i's Avatar
so how about a stock replacement recomendation for a '98
thanks
