Installing Head Studs While Heads Are On The Car
Old Feb 18, 2003 | 08:47 PM
Phate's Avatar
Default Installing Head Studs While Heads Are On The Car
Guys,
I am going to be pulling my heads in a few weeks to have some add'l work done to them. I have a set of studs that I want to install this time around.
Is it possible to pull one bolt at a time and install the studs so that I don't have to go through all of the trouble of cleaning the coolant out of the holes in the block? This may appear to be time consuming, but it took me a loooong time to get all of the coolant out last time.
Thanks,
Scott
Old Feb 18, 2003 | 10:20 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: Installing Head Studs While Heads Are On The Car
Yes, it is possible to do this way, but you will probably take longer doing so than it takes just to remove the head and clean out the holes. Unless you really are just trying to save a head gasket from being replaced, I'd just pull the head off.
Tony
Old Feb 18, 2003 | 10:27 PM
akw408's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Scott 98Z M6:
<strong> Guys,
Thanks,
Scott </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I don't see why you can't do it, but I think it'll be more of a pain in the *** to get the studs in there when the heads are in place. But you can do it. Cleaning the bolt holes didn't take me that long, I just stuffed some paper towels down there and left it overnight. Next morning I pulled it out and put some more paper towel and they came out dry. Took me maybe a total of 20 minutes to shove paper towel in there?
Old Feb 18, 2003 | 10:33 PM
Fly By's Avatar
can you remove the heads with the motor in the car and with studs in place <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Feb 18, 2003 | 10:48 PM
akw408's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Fly By:
<strong> can you remove the heads with the motor in the car and with studs in place <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes, plenty of room.
Old Feb 18, 2003 | 11:55 PM
Phate's Avatar
Thanks guys, looks like I will be doing cleanup again.
Thanks,
Scott
