Big Cams cause to low of vacuum?
The shop that installed it says that its because the cam is to big and causes to low of vacuum.
I am having problems with it upshifting to early at WOT and also the TCS light comes on and wont let me turn it off or on. ive read some post of other people having the same code and having problems with the tranny shifting to hard and hard starts with some bad idling. which have also
if anybody knows what i need to do to fix this problem, PLEASE let me know
Jason @ TSP did the tuning, so I'll ask him if he remembers what he did to get rid of the code.
The cam we had at the time was bigger than Brains cam - in stock CID too.
The car idles perfectly at 800 RPM, but I've since bumped it to 900 to make driving a little easier as well as pick up a little vacuum (72'ish kPa --> 65'ish kPa). I have a SPEC Stage 4 clutch with the solid hub, and the 100 extra RPM makes a big difference in taking off smoothly from a stoplight
has anybody done this yet? i dont have 1.3 yet, but it looks like ill have to order it now. if you have used this to fix it, what did you change on the table
Please let me know Joseph. today i went to the 1/4 track and had to manually shift my A4. my times sucked but i finally hit the 11's.
but now after the cam, my regular driving is putting it between 55-65 alot. there is still some lower and at WOT its in the 90's and some 100-105 or so.
i think maybe im suppose to make thet 55-65 MAP window smaller or maybe raise it, but i wonder if this is going to fix the problems or if its just going to make the light not come on
