Looking for a mild street cam for 97 vette
Old 11-30-2009, 08:16 PM
radioflyer86's Avatar
Default Looking for a mild street cam for 97 vette
I have a 97 vette with all the bolt ons i can find and YT 1.8 rockers for a little extra power. This is a daily driver but I'd like to get little more power without sacrificing street manners. The plan is to get a set of 243 heads with all new valvetrain components and a mild cam.
I'd like a non-lumpy idle and good low end power even if it means sacrificing the top end. I rarely push past 5000 RPM due to insane drivers pulling out in front of me so i need a nice fat torque curve in the 2-4K RPM range.
So far the GM hotcam seems like a good canidate since i've heard re-tuning isn't essential (although reccomeended)
Suggestions?
Old 12-01-2009, 02:10 AM
thewholefnshow1's Avatar
Look into a 224/228 cam or TSP 224 LSA 114 or TSP 228 LSA 114 From what I've been reading that TSP 224 is a great street cam just have a good tuner.
Old 12-02-2009, 03:15 AM
john59's Avatar
224/228 Great Street cam I love it
Old 12-02-2009, 04:52 AM
PREDATOR-Z's Avatar
Suggestions?
If you do not plan on tuning the motor then do not touch it further. Tuning is essential and mandatory. Heck tuning a stock setup will yield extra power.
Old 12-02-2009, 05:45 AM
69LT1Bird's Avatar
If you do a mod, especially something as costly as a cam swap, and it doesn't need a tune change it is not worth doing. Who ever told you that you will not need a tune change should not be giving advice.
Old 12-02-2009, 05:56 AM
Rob
Rob's Avatar
I'm running a FTI 220/224 and love it. Makes almost as much power as my old 228/232 Comp I had and a lot more torque down low. Very mild idle at 800 rpm. It lopes a little when cold but really not bad at all. Great all around cam. Very easy to tune also.
Old 12-02-2009, 09:30 AM
Interspy24's Avatar
I agree with Predator-Z, without tuning I'd leave your setup as is.
Old 12-02-2009, 10:15 AM
LSX Mechanic
Damian's Avatar
First off, get the car tuned after whatever mods you choose or don't waste your time/money.
This statement was made back when there was zero tuning software available for LS1's. Back in 98-00, people had no choice but to run the Hotcams without tuning.
You also have to take in account the 1.8 rockers you're running.
For what you're wanting a 218/222 .530-.540ish 115LSA cam would fit the bill. Will peak around 5900, make more midrange than a stock cam, idle very close to stock, and would run fairly decent with no tuning (if you insisted on not tuning the car).
Old 12-02-2009, 05:21 PM
PREDATOR-Z's Avatar
I would agree with Damian but 218/222 .563, .566 112+3 LSA,
38 IVC for stock peak and 300 rpm shifts past that, -4* overlap so fairly stealthy.
