Cam help for Winter project... need help with PTV and suggestions
-Patriot Stage 2's with 2.05 intake valves, 67cc chambers, Patriot Gold .650 dual springs
-.040 Cometic head gaskets(thin)
-Stock 02 short block
I contacted two vendors today Thunder and Texas Speed. I pretty much ruled out a MS4 as it won't work and I was told that. Here is the list of the ones I am looking at but if anyone has a stick that would work I am all ears:
-El Torro 230/230 612/598
-Torquer v.3 231/234 643/598
-MS3 237/242 603/609
-Tsunami 235/240 654/609
-Raptor 236/242 615/615
Interesting thing I heard from Thunder was the T-Rex is the cam for stock heads but if you change them the Raptor is the better grind to use. I thought that odd but the way he explained it I understood.
with the thin gasket i don't think you could go much bigger. i had to fly cut for a 238/242 with afr 59cc heads and the .040. they are 59cc but the afrs at 59cc still have as much valve drop as a stock head unmilled.
I have ran the 232/234 xer cam on a 112lsa 110 icl and i loved it. great mid range and good upper rpm pull and ran very well with a 150 shot.
Any dyno numbers or track times with that cam?
afrs 59cc (mine others may vary slightly, mine are from LG)
intake .155
EX .190
I had cut the pistons to a bigger cam before i had ran this so i can not say what ptvc whould be
I never had it tuned but ibeat my buddie by 2 car lengths that had a dyno'd 620hp 502 (crank) crate moter in a 69 camaro spraying 125
lost a rod bearing due to low oil a month after and switched cams to a 238/242 after the new engine.
but the 232/234 had way more midrange i would explain it as explosive mid range while spraying
i also ran the .040 gasket with the 59's for 11.8 scr
I was thinking more of having these massaged a little by hand by a local porter I have used before for < $500.
These had the flow numbers already pretty decent.
