Help me with my new build!
Now, I would like to hit 10's,
with this build as well. I have been doing some minor research, and here is what I think I might end up doing, possibly changed with some of your help.Power adders:
Cam, headers, intake, (gears-if you want to count that)- and at the very end of the modding, I would like to spray the car as well.
Cam: Now I have been told that the T-Rex cam has been tried and true, kickass cam only cam. Also, I have been told it works well with nitrous too, what do you guys think, do I have a better choice than that?
Headers: I was thinking of going with coated pacesetters, any other ideas? These headers are cheap, and seem to work well...
Intake: I was originally planning on going with a FAST intake, but I was told that the T-Rex works best with the LS6 intake, is that true?
Since the car is a 6-speed, I was thinking of going with 4.10 gears.
Also, since we are on that topic, since forth gear is 1:1, around 6500rpm, with a stock sized tire, what speed would you be going with those gears/rpm?
Spray: Don't have much experience with it, but by the time I get around to finally spraying this car, I probably will have a decent amount of experience with it. 100 wet shot? I definitely need some guidance there.
Overall it should be a pretty good build. Thanks for any tips/info.
You are going to need to put a 15 rim with some Mickey Thompsons on to reach that goal. I am not sure anyone has made it there on a 10 bolt, so your definitley looking at a 12 bolt or Dana S60 to hold up. I doubt a 100shot will be enough. I am doing a 150 shot but over 175-200shot, back to supporting mods again lol.
You can use a gear calulator to figure it all out here is one http://www.richmondgear.com/101032.html
Have you found a car yet?
Clutch, I will probably end up with a spec 3 or 4, but that is a ways down the road.
Rear end, I will prob go with a 9", but I have been told the 12 bolt is pretty good too, so I will decide when the time comes.
Tires, I am not worried about at the moment, I know, 15" rims, and get some MT ET drags, or some Hoosier QTP's.
Suspension, I will definitely need help with what to go with.
I do not have the car yet, but I am aiming to get an 01-02 TA, so I don't have to get the LS6 intake later on down the road.
That being said, it used to have spray on it before I got it and I saw it skull drag a bike on the street. He never ran it on the track with the spray but it was probably a good second faster on a 150 shot. So, yes, this cam is great for nitrous.
That's all I got for now. Good luck and keep us posted.
to the op, do u want to go 10s cam only or with spray? the trex is not a street friendly cam at all.
I do know the shift light was set at 6800 and would still pull hard to the rev limiter at 7100.
We have most of that stuff, the 9" or 12 bolt, suspension parts and we can do an amost identical cam. with the supporting mods (hardened pushrods, valvesprings, etc...) Let me know if I can help, be happy to put together a package deal if you like.
