Rod bolt failure limit
K-member must be removed to drop the pan. Don't remove the cap but replace one bolt at a time. I would only use Katech bolts since you will not be getting the rods resized. This is a contoversial topic but if you search there is a lot on it in here. Basiclly in THEORY ARP's are physically bigger and exert different clamping force thus distorting rod ends resulting in spun bearings...
im guna go ahead a subscribe. im also going to be doing a H/C swap. ill be dropping the whole front k member, so if its worthwhile doing rod bolts then i might.
but, from what im reading, rpm is harder on rod bolts than hp. ive seen some nitrous guys spraying and hitting 6-650 to the wheels on stock rod bolts, but they arent doing 7k either...
