why arp . . .
John
but if u dont want ur bolts, give them to me
i need em \/
thank God i have almost everything ready for the swap i just wanted to make sure on the head bolts Trending Topics
If you are digging into the motor and funds permit, please use them.
I personally would not use any TTY fasteners if I can avoid, and at best a stock rebuild I would probably use them.
Studs are used for repeatability on the clamping force, also that it helps keep debris and fluid out of the bolt holes. If the heads come off, the TTY must be thrown away which can get costly if your into the motor a lot.
TTY has been used for Factory Production due to the repeatability of quality, Most times they are Torqued down with a "Gang Driver" so I think that makes a diff compared to hand doing the torquing.
Since you have the bolts, I'd say use them, but if you want to ensure a good running motor with proper clamping force, go ARP.
Also, once you put the studs in, they are in, no worries of cross threading the block or something like that.
On an F-body tho, Im not sure cuz I dont own one and have never worked on one, but I can imagine studs interfering with head removal/installation due to the cowl being in the way. You could remove those few studs with the head in place tho to get around this issue...but that sorta negates some of the advantages of studs.
