Cam comparo
Old Dec 8, 2009 | 04:07 PM
BLUEBYU's Avatar
Default Cam comparo
Finally decided on two cams:
Comp Cam- LSR™ Cathedral Port, 281LR HR13 (231/239 0.617/0.624 113 LSA)
or-
Comp Cam- XFI™ XE-R, XER281HR (232/234 0.595/0.598 112 LSA)
Any experience with either of these grinds or recommendations is much appreciated.
My current cam is a TR224/224/114 with TEA Stage II heads, LS6 intake, Hooker headers w/ 3" ORP.
Thanks.
Old Dec 8, 2009 | 11:59 PM
BLUEBYU's Avatar
There has to be some guru's out there that have some input.... trying to get some idea of the pros/cons that I need to be aware of... thanks.
Old Dec 9, 2009 | 11:18 AM
BLUEBYU's Avatar
Anybody? Springs will handle both, but will the larger cam have driveability issues. My bro is experienced with HP Tuner, so that should not be a problem. Also, Comp Cam indicates the second cam is for race only applications.... I mostly cruise with some WOT fun. Thanks for the input.
Old Dec 9, 2009 | 11:36 AM
01ssreda4's Avatar
How do you like the tr224 with the heads?
Old Dec 9, 2009 | 11:56 AM
BLUEBYU's Avatar
Made good power and torque... and very driveable. Just looking to take advantage of having the engine refreshed with new pistons and bearings. Stock pistons did not like the nitrous. Btw, I will be selling the TR224 if you are looking for one.... in original box and spec sheet.
Old Dec 9, 2009 | 04:41 PM
BLUEBYU's Avatar
Thanks for the input.... thought this forum had some people with knowledge in the cam world.... btw, 232/234 is my decision..... now let's see what she can do.
Old Dec 9, 2009 | 07:48 PM
01ssreda4's Avatar
I have the exact same cam. I love it for what it is. Just curious how it performed with the heads.....
Old Dec 10, 2009 | 12:32 AM
transamfreak01's Avatar
is this ur dd? i would go with the 231/239... im going with a cam simliar to this
Old Dec 10, 2009 | 06:55 AM
teke184's Avatar
the 232/234 is basically the TSP torquer v2
a very well used cam
makes good power and tunes to drive very nicely.
i have the v1 of the cam and am happy with it, power range is very useable
Old Dec 10, 2009 | 09:10 AM
teke184's Avatar
both cams are basically the same.
i doubt you'd notice a difference on the street.
Old Dec 10, 2009 | 10:12 AM
BLUEBYU's Avatar
Thanks for the feedback.... I decided on the 232/234 cam because the max lift is where my heads are max flowed at .600. My engine builder does not believe the additional wear and stress on the valve train is not necessary. I should see 30-40 hp increase with the new Mahle pistons and degree increases on the cam.... I will post pics when the build is complete probably early 2010 and get it dyno'd in the Spring.
Old Dec 10, 2009 | 10:43 AM
streetassasin's Avatar
Im happy with my cam, the cars my dd, specs in sig
Old Dec 10, 2009 | 11:05 AM
wytry's Avatar
I have the second cam you listed (TSP's Torquer v2). Love it, very streetable, makes good power especially if you have good heads/intake. I'm a 6 speed on stock tune too.
Old Dec 10, 2009 | 04:57 PM
BLUEBYU's Avatar
Who sells this cam? Lift is tolerable.
Old Dec 10, 2009 | 05:07 PM
ringram's Avatar
Do some research mate, IIRC Comp says the LSR lobes even though higher lift are easier on the valvetrain than the XER lobes.. Better profiling etc.
Old Dec 10, 2009 | 05:36 PM
BLUEBYU's Avatar
Yes. One of the techs at CC indicated the LSR lobes are a new design but I did not confirm how they compared to XER design.
Old Dec 10, 2009 | 05:46 PM
blu byu EH's Avatar
Vengeanc's sells the cam, its great for ls6 heads!
Old Dec 10, 2009 | 06:06 PM
BLUEBYU's Avatar
Can you point me to where you found this information? Thanks. Fwiw, it is great to be back on this forum.... I thought I was finished with my project... I have not touched this girl since 2004...
Old Dec 10, 2009 | 10:56 PM
blu byu EH's Avatar
https://www.vengeancerd.com/ecart/pr...7D.605-113-LSA
Here you go!
Old Dec 10, 2009 | 11:35 PM
BLUEBYU's Avatar
Thanks, but I was referring to the gentleman from the UK. i would like to read the information regarding the lobe comparison.
