ms3 flycut?
Old Dec 10, 2009 | 07:29 PM
malott's formula's Avatar
Default ms3 flycut?
do i needa fly cut if i run a ms3 with prc stage 2.5 5.3 heads
Old Dec 10, 2009 | 08:14 PM
00 black ss's Avatar
You don't but its always good to measure just incase. And I'm pretty sure you need to have the valves sunk in order for the ms3 to fit
Old Dec 11, 2009 | 09:53 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
And as a note, the heads MUST be setup originally for the MS3. If you get some used heads that weren't built for the MS3, you'll have clearance issues!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Dec 11, 2009 | 10:56 AM
blue99fbody's Avatar
my pistons had marks on them from the valves with stock heads and ms3
Old Dec 11, 2009 | 09:26 PM
carreras's Avatar
What would be the biggest cam u could run with those heads if they weren't set up for the MS3?
Old Dec 11, 2009 | 11:11 PM
mastercoryd's Avatar
not to hijack but i have a stupid noob question... to flycut a piston? what is that process? is it a diy or u have a machine shop do it?
Old Dec 11, 2009 | 11:17 PM
badss_02's Avatar
You would take them to a machine shop... I am sure you wouldn't have the tools needed to do that.
Old Dec 12, 2009 | 01:54 PM
buy the tool and diy
Old Dec 12, 2009 | 02:05 PM
SIC GTO's Avatar
so what do you have to do in order not to have these marks???
I am installing my ms3 on stock heads in 3 weeks!!!
Old Dec 12, 2009 | 02:16 PM
01FbTaWs6's Avatar
flycut
Old Dec 14, 2009 | 01:56 AM
ZTwentyAteU's Avatar
I didnt have to flycut on ms3..I don't see how you guys hit the pistons at just over .600 lift on stock stuff. Must be stretching valves!
Old Dec 14, 2009 | 05:47 AM
01FbTaWs6's Avatar
its not just the lift that is the issue. Its a combination of lift, duration and ICL. Also, whats an acceptable clearance to you? .100 on intake AND exhaust?
Old Dec 14, 2009 | 09:04 AM
It really depends how the heads were setup when originally sold. The best way to find out what you can run comfortably, is to measure the free valve drop (distance the valve travels from its seat until it hits the piston at TDC) on intake and exhaust. Based on those numbers, we can make a recommendation.
__________________
