what is the difrence lq4/lq9.what would be best for me
i currently own a 92 typhoon, 6cyl broke a crank again. want to do a ls conversion, what one would be best for me lq4/lq9,with boost i will be using a t66. also can people post up motor specs on these two. Like what the crank and rods can handle for power thanks.
Sorry to hear about the v6 dying on you. The difference between the two is mainly the pistons, the lQ4 has a 7cc dish and the lq9 has flat tops. The earlier lq9 has better connecting rods with full floating pins, and both the later lq4/lq9 use this design. Both engines use the same block, crank, and heads. The 99 and 00 model lq4 used a crank with a thicker flange where the flywheel bolts on to accommodate the 4l80e tranny and newer engines use a spacer with the same crank as the other gen 3 engines. For more info and specific changes by model tear try inputting "lq4/lq9"(with the quotation marks) in the search here and on the performance trucks site(click the tab at the top of the screen for performance trucks).
