Performance Induction's NEW cylinder heads
While pivot location and pushrod location are influences on a rocker design, it seems valve location would be as well. Changing only one with a given rocker can lead to serious problems, like only half of the rocker tip sitting on the valve tip (extreme case). Therein lies my question: if they moved the valve centerlines, similar to the old "60/40" trick, how did they get it to work with stock rockers? Was it not enough to make any significant impact, or where other variables changed to accomodate?
and yes if you only change one given you will have problems-that's why everything needs to be changed accordingly
I did this weekend Shawn. Probably misspelled a lot but what would you expect from an engineer, proper spelling?
Other than being able to sell the best products out there, I have no *stake* in Performance Induction. Why would you ask?
Everyone wants free stuff. I guess when the utility companies, the tax man and the health insurance people give me free samples, I may be able to do that. Until they do, y'all gotta pay to play.
motor is out of the car and its getting prepped for heads. I just really want info on them before i buy them.
"This is a business not a charity. Maybe one day Unicef will get into the head business but until then we are the people to see." ......Joe Dirt. LOL
you can use ls3 rockers on stock ls1 heads if you put the pivot location and pushrod hole in the correct location for them
Have you actually done this on LS1/LS6 heads? How much do you charge for the machining and the stands if they are needed?
Thanks.
Jon
So we agree that valve location is important in rocker selection afterall?
Well what if you don't change the pivot point? Contrary to your last post, that valve location becomes pretty important in rocker selection doesn't it? I'm not trying to argue theory or design here, I'm just asking a simple question as to the design of this particular head: what did they do to allow the use of stock rockers with altered valve centerlines? It was a question intended to coax a little more specific info as to the design of the head, not to start an argument.
how is it that you can run an ls7 rocker on both a 4.00 bore etp ls7 and a 4.100 bore etp ls7 when they have different valve centerlines?valve location doesn't determine if the rocker uses an offset or not-pushrod location does.
look at it this way-if you have a rocker setup that works,then move the valve guide .060 to the left,then move the rocker pivot and the pushrod .060 to the left-everything is still in the same location relative to each other.
Looking forward to getting a couple sets of these and would like to use the smaller runner sizes on the low 400 cube setups. Some of the set ups are too big for the 215's and not going to benefit from the flow capabilities of the 245's with the restrictive intake manifolds being used other than a sheet metal or carb manifold set up so is their anything in between or is that the only configs that will be available.
we do offer the smaller ports in the larger bores. We can pretty much mix and match any of our port and chamber combos.
Thanks
Tommy
