Guys with 853 comes inside
Old Dec 18, 2009 | 10:48 PM
kevins2000LS1's Avatar
Default Guys with 853 comes inside
Hey im still up in the air about nitrous or cam only. But i have decided that im NOT going with head for awhile so!!! Im wondering what you guys that are still running factory 853, are doing with cam only at the track ET wise? I have sen alot of fast cam only cars but alot of them have 243 heads.
Old Dec 18, 2009 | 11:30 PM
butler's Avatar
10.93 @ 124.5 mph with a 4000 stall and 3200 race weight
Old Dec 19, 2009 | 07:51 AM
00 black ss's Avatar
12.5 on a 2k launch. Obvisouly has 11's in it. Had to go easy on 10 bolt bc I was 90 miles away. Once I get a rear should see mid 11s easily. I'm going with stock 243s soon and should pick up 15 to 20 at the wheels. If your on a budget pick up stock 243s
Old Dec 19, 2009 | 08:07 AM
Ok keep them coming guys. Im running 12.0's now wanting to add a cam or nitrous. Im sure i can pull off a 10 second passes with the gas but like to have the power all the time and the sound of the cam to boot. Ik now im probably not goinng to get a 10 scond pass witha cam but wondering how cloase with 853 and cam only i can get. I still have gears, ram air to do as far as bolt on's.
Old Dec 19, 2009 | 10:53 AM
blue99fbody's Avatar
i had stock 853s with a ms3 and went 11.98@116 with a m6 and tune was for a 150 shot so there was some left on the table with more agressive na tuning
Old Dec 19, 2009 | 11:08 AM
gixxer75094lt1's Avatar
this is a good article. haider saba (fantaz28) on here was featured in gm-hightech awhile back ran 10.90's using stock 853 heads but swapped out stock valves with manley valves and patriot gold springs and ran a big cam. he did though have a th400 and a 12 bolt but nothing too radical motor wise. good luck.
http://www.gmhightechperformance.com...aro/index.html
Old Dec 19, 2009 | 12:57 PM
Thats a very good right up there. Got me thinking about a valve job now. Bad thing is i just had the damn driver side header off removing on of my manifold bolts. . But if i pull the head how much do stock 243's usually run?
Old Dec 19, 2009 | 06:32 PM
supersick99z's Avatar
mods in sig on stock 853 heads but no track times just dyno
Old Dec 19, 2009 | 07:59 PM
Anywhere from 400 to 600. Check out the classifieds on here. Also look for 799 series head. Same specs as the 243s just the older model.
Old Dec 19, 2009 | 08:07 PM
02 BLK WS6's Avatar
Stock 853's here, but not for much longer.
Old Dec 19, 2009 | 11:39 PM
You spraying right? If so how much?
Old Dec 20, 2009 | 08:30 PM
Come on cam only guys with 853's. show me some et's
Old Dec 20, 2009 | 09:33 PM
blubyu02's Avatar
no et's yet but 386/379 na and 504/538 150 shot cam only and stock ls1 intake m6 and some worn plugs lol
Old Dec 21, 2009 | 08:34 PM
which cam you go with or custom?
Old Dec 22, 2009 | 12:09 PM
68chevypu's Avatar
I thought the 799 was the truck head? I was under the impression it had the same intake runner design but was a bigger chamber. Is that incorrect?
Old Dec 22, 2009 | 12:14 PM
Avaric3's Avatar
thats correct. the 799 head will lower your compression so if youre stayin n/a youll def want the 243s
