Cycling ARP head studs
Here is a little blurb I found on ARP's site--
1. The friction factor changes from one application to the next. That is, the friction is at its highest value when the fastener is first tightened. Each additional time the fastener is torqued and loosened, this value gets smaller. Eventually the friction levels out and becomes constant for all following repetitions. Therefore, new fasteners should be tightened and loosened through several cycles before applying final torque. The number of times depends on the lubricant. For all situations where ARP lubricants are used, five cycles are required before final torquing.
Frank
Just to clarify, by cycling I don't mean coming up to the final torque in 3 steps. I mean once you get to your final torque back off and retorque each bolt 5 times.
Here's what I did. Torqued the nuts in 3 even steps reaching 80ftlbs. Then when through and backed off one nut at a time and retorqued it going through the torque sequence. I did this on both heads 3 times. I will do a final pass tomorrow.
As for the Moly Lube, I wasn't aware they had out a new version. I did know they had been going back and retesting many of their fasteners and then revising the torque values. For example, after laboratory testing, they increased the LS1 head studs from 70 lb-ft to 80 lb-ft.
