Iron Block folks in here.
I'm going new 6.0L block and keep the stock 4.00 bore. Using a 6.0L crank, Diamond pistons, Manley rods, a custom ground cam w/ matching springs, and topping it off with my current LS6 heads (no money left for porting).
I hope it is gonna work well and make some good power. I really don't know what to expect. I guess a lot of it depends on the cam.
I figured why bore it now if I don't need to - I'll save that for the day I tear it apart and build a stroker out of it
Let us know how your decision goes!
I agree with RODENT 100% as i ran a 427 iron motor before my C5R motor and did a ton of research. If your staying N/A 4.060=max bore but MUST SONIC TEST to make sure you have enuff meat, as many of the new iron blocks are to thin for 4.060. Matched with a 4.00 crank you have 414 cid. DON"T RUN more than a 4.00 crank or your LOOKING for HUGE reluctor wheel problems and oil consumption with a 4.125 crank on a ironblock.
If your spraying or planning GAS or other F/I then stick stick with 4.030 bore and that matched with a 4.00 crank gives you 409 cid and leaves room for rebuild if ever needed. IRONBLOCKS a GREAT way to go if you want extra strength don't mine 100 lbs in front and if you stay anywhere from stock crank to 4.00. Throw in the new eagle crank (4.00) and build yourself a kick azz iron superstroker!
So, to be on the safe side, only bore it to 4.030 and then when the time comes to do a rebuild, have it bored to 4.040 for the service bore?
I plan on getting my 6.0L block tested very soon, so hopefully I'll have a good block to make the bore bigger...
Bill
I was looking for around 400 rwhp - is that wishful thinking?
If you are debating about staying all aluminum I would hold off until someone gets their hands on an LS2 block. I have heard it will be compatible with LS1 internals.
I hooping this becomes the cheap option for going all aluminum big bore.
Is this correct?
What is the stock bore and stroke on 6.0L block?
I like the idea that BLK02WS6 has with stock 6.0L block and 4" crank
Don't worry about the extra weight up front we can help ya get that all worked out.
