What cam???
Old Jan 4, 2010 | 10:48 AM
88fiveoh's Avatar
Default What cam???
I'm looking at putting a cam in my car but whas the biggest cam i can put in my car without upgrading my springs? any suggestions?
Old Jan 4, 2010 | 10:55 AM
BaddBird's Avatar
Uh!! what kind of car Fbody, vette , gto???? You really should upgrade the springs anytime go with a bigger cam.
Old Jan 4, 2010 | 11:02 AM
88fiveoh's Avatar
its ls1 out of a 2000 camaro for my ls1 mustang project. moneys a little tight right now...should i wait on the cam and spend the money on upgrading the springs?
Old Jan 4, 2010 | 11:09 AM
cookba's Avatar
just cause its the biggest cam doesn't make it the right cam. some of the milder cams are better suited for most apps. But if money is tight, just hold off till your good. Do it once, Do it right.
Old Jan 4, 2010 | 11:21 AM
SweetS10V8's Avatar
I wouldnt change my cam and try to reuse the stock springs if you paid me.... You need to upgrade springs too!!!
Old Jan 4, 2010 | 11:31 AM
88fiveoh's Avatar
i wannt to the use MS3 cam? what do you guys think about that?
Old Jan 4, 2010 | 12:03 PM
NC98Z's Avatar
You would be better off to buy the cam kit from TSP cause you gonna need springs and pushrods. If you arleady have the MS3 I would call TSP and get what PRC doubles they recomnmend and yes you still will need pushrods.
You would probally be better off leaving the motor stock and upgrade you suspention to handle the ls1 power. Quicker times anyway.
Old Jan 4, 2010 | 12:08 PM
teke184's Avatar
figure stock springs are good to about .520" lift
the ms3 is upwards of .600" lift
you do the math.
any cam that CAN run on stock springs isn't worth the effort!!
Old Jan 4, 2010 | 12:23 PM
sscamaroburn02's Avatar
i would always upgrade springs. just a cheap investment to me. the MS3 is a good size so there is no question here.
Old Jan 4, 2010 | 12:37 PM
Formulals187's Avatar
If you want the motor survive for any sort of time you better upgrade the springs.
Old Jan 4, 2010 | 12:48 PM
Bo's 98 TA's Avatar
Just don't go the cheap way save up the get the right things so you don't have to go back and do it again.
Old Jan 4, 2010 | 01:30 PM
VeTTeMaNC486's Avatar
you need upgraded springs for any cam other than stock that I am aware of. Hell, even a ls6 cam you need atleast ls6 springs.
Old Jan 4, 2010 | 01:45 PM
TooLateVTEC's Avatar
you do the math.
What he said.
Changing springs and push rods are part of a cam swap/end of story.
Old Jan 4, 2010 | 02:00 PM
zacht's Avatar
he might be able to do something budget like. what about some LS6 springs, there plentiful in the classifieds. and pushrods in the classifieds. the ls6 springs are good to 560 lift i think.
i bet if a guy really found some deals and did it on the cheap could get a cam/springs/ pushrods for 3-400 bucks...looking cheap.
Old Jan 4, 2010 | 02:13 PM
223HAWK's Avatar
Springs are easy to change..even in/on car..Took me about an hr maybe an hr 1/2 to change mine when I upgraded to my car. The Magic Stick cams sound mean..I have the MS4..Love the way it sounds..Makes OK power..I couldve shoped around more..Heads and more cubes I think would make me a lot happyer..but Bigger cams like RPMs..unless you feel like replacing the bottom end soon..I would go that big and turn it 7000 +..
Save your money..its not worth putting a cam it and going..do it right and do it once..
Old Jan 4, 2010 | 02:54 PM
BaddBird's Avatar
Get yourself a set of Pac 1518s ($190) good to .650 lift use you stock retainers and locks. If the motor is out it should be an easy install. Do yourself a favor and no matter what springs you upgrade to measure for correct installed hieght.
This cam aint happen with stock springs.You can run upgraded springs with a stock cam. But you cant run an upgraded cam on stock springs and expect it to last.
Old Jan 4, 2010 | 03:07 PM
88fiveoh's Avatar
ok, so after reading what you guys have said i just need to save my money and do a cam, push rods, and springs swap. tsp sells a kit that i think i'll look into.
Old Jan 4, 2010 | 03:41 PM
223HAWK's Avatar
Locks and Retainers..I see..maybe...Not seats or bases I guess..on a high lift or fast reving engine..coil binding happends..broken rockers and springs..
Patriot has a set of dual Springs/Locks/Retainers everything..for $250. Some of the best springs I think..Had very good luck with their products..
Old Jan 4, 2010 | 05:45 PM
JPH's Avatar
JPH
Find a vendor that will make you a killer deal on the cam, springs(beehive), pushrods and ALL the gaskets you will need for the swap!
Old Jan 4, 2010 | 06:13 PM
USArmyZ28's Avatar
www.thunderracing.com and dont look back.
