magicstick 4 cam
my car is a street car, drive it about 2 times a week or on the weekends, whichever.....it has some quirks in it, its a big cam to lug around, 1500 rpm's is definitely not its favorite cruising rpm, lol....but other than that, once i figured it out, i love just driving it and hearing it rumble.....and for later down the road when i go back and do some head work....it will really help it out alot, gotta plan ahead you know....
Try MS4 in the string, look in Drag Racing Results, Dyno Section, and Gen III Internal for answers.
As for the comment on Fastest Cars with XXX Cam comment, I will say this. There are cams out there that have gone fast BUT this was only due to the car's set up. 95% of Fbodies out there do not meet the same requirements like......
Raceweight
Tire
Suspension
Gearing
Transmission
Just to name a few, most of the record holders are LIGHT weight, HIGH Gear, Drag set ups.
True Street cars should take into consideration with the Top End cams is that the Mid range sucks and drives like it has no ***** until 3800-4000 rpms.
Depending on actual useage, a good all around cam should have at bear min 224/228 Dur, if NOT 230/236 and LSA in the 112/114 range and a decent lift, 550-590 is fine too.
Jon
Now if I can get someone to give me a set of heads, lol. I am still running the stock 243's and the stock LS6 intake. It runs strong, but it needs those upgrades to be a beast. The Best V8 Stories One Small Block at Time
engines arent vagina's. u shouldn't just stick anything u think is big in there.
most of any chicks will tell u, it's not the size its how its worked !!
