g5X-3 with stock heads
Old Dec 21, 2003 | 06:39 PM
SMOKIN01TA's Avatar
Default g5X-3 with stock heads
does anyone know the p/v clearance on a G5X-3 cam with stock heads. also what are the specs and who makes it. was looking at the TR 230 cam, it made 410 or so on stock heads but if the G5X-3 can make 430 on stock heads i will look into it if it has a safe p/v clearance.
Old Dec 21, 2003 | 06:41 PM
blueWS6's Avatar
you have to flycut the pistons with the g5x3
Old Dec 21, 2003 | 06:42 PM
SMOKIN01TA's Avatar
ok nevermind
Old Dec 21, 2003 | 09:04 PM
HOTROD98Z's Avatar
I beleive you can still run the G5X3 on stock heads and not have to cut the piston, Call LG and ask them to be sure, talk to Lou or Louis they will be able to help you out.
Old Dec 21, 2003 | 09:07 PM
WS6snake-eater's Avatar
You don't have to cut the pistons, as long as your heads are not milled. I've got that cam and P/V is good. Close but good.
Old Dec 21, 2003 | 09:22 PM
HOTROD98Z's Avatar
Do you have any numbers out of your setup yet?
Old Dec 21, 2003 | 09:52 PM
No I went by MTI on Saturday to get tuned and dynoed, but Jayson was getting married, so I will make an appointment for later in the week. Congratualtions Jayson!
Old Dec 22, 2003 | 12:01 AM
SMOKIN01TA's Avatar
would the tsp 231/237 work also. is it better.
Old Dec 22, 2003 | 02:26 AM
Beast96Z's Avatar
The TSP 231/237 will be easier on springs, but won't make as much power. The X-3 is a bit bigger and has harder lobes.
