Replaced Oil Pump. Low pressure, no noise.
#44
I am having the same problem. I just installed a slp unit into my 98 camaro. Cold idle is great and after warmup drops down to under 20psi. I replaced the oil pressure switch (without removing manifold) and still has same pressure. All signs point to o-ring. I will be replacing the o-ring by dropping the oil pan this time. That way I can make sure the o-ring seats nicely.
#45
LS1Tech Sponsor
BUT, that being said, we can get you anything you want, from all stock replacement, to more Ci like a 383, just forged pistons, or whatever else you want. Just let us know!
#46
Moderator
We can definately get you what you need. the problem being, your rods/crank may not be in spec for a standard bearing, so you would first need to get those parts checked to see if there is a problem.
This engine is already a 422 CID built from a 6.0L Iron Block.
We'll have to see what is going on, parts-wise (I hope something minor and simple, even though it looks like I must pull the engine.)
#47
i fixed my oil pressure problems. turns out it was the OPSU after all. I replaced the OPSU 9 months ago when i did my intake swap, but i guess these things are built like crap. My oil pressure is insane now with my unnecessarily-installed Thunder Racing pump...im putting out 55-60psi at cruising speed.
#48
Moderator
Since it was the OPSU, the oil pressure was always truly up, though, right?
#49
took me about an hour or so to replace the OPSU today in 20* weather. you should be able to swap out the sender if you got small hands, but i had the pull the manifold forward because i couldnt unclip the harness. buy the OPSU made by Standard Auto Parts...my delco unit only lasted me about 9 months
#50
Moderator
I guess what I'm saying is ... unless someone tells me the sender can somehow restrict oil flow where the pressure lowers, there's no need for me to do the sender; I have already hooked an external gauge to my car and verified the oil pressure is truly low.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#52
Moderator
Just closing the loop.
Got around to opening up the engine. #4 Main Bearing (something that could not be seen with the oil pan only removed) was worn (not spun) and oil was leaking past that bearing. All other bearings were pristine.
One of the cylinders had water in it. Gasket had a hole at that spot. Piston is fine.
One of the cam lobes was a bit damaged; looks like a lifter was not rolling there anymore. But, Comp Cams says it looks possible the cam can be reground to a simlar profile. I'll know today.
Thanks for all the replies I received in this thread before.
#53
I know you wont like this. And i know you wont believe me but im going to say it anyway. 1/2 of your main bearing problem was probably caused by using the wrong oil.
Think of it this way take your thumb and pointer finger and make a circle. Stick your fist through it. (doesnt fit does it) well make it. What happens? Either you enlarge the circle or your fist is no longer a fist. Thats what happens when you use thicker oil that you shouldnt. The molecules in the oil break down OR you gouge your bearings. Either way its not what i would want. 20-50 doesnt belong in a daily driver. Unless you built the motor really loose. And i doubt thats the case. you really shouldnt need over 10w30. JMO take it for what its worth.
#54
Moderator
ljsracing ... I agree with you.
As I mentioned, until the low oil pressure problem:
I had been told, however, that 10/40 synthetic was acceptable as 10/30 dino.
Thanks for the advice. I'll keep that in mind for this next engine.
(I've always run no heavier than 10w40 the whole time I had this car.
