Comp Cam springs 26925
Old 01-22-2010, 10:17 PM
denscor's Avatar
Default Comp Cam springs 26925
Has anyone used these springs before? Comp Cams 26925 Ultra Dual Valve Springs; Designed for GM LSr Camshafts, .650 Lift, 1.290" OD
Old 01-23-2010, 10:25 AM
XtraCajunSS's Avatar
I've used them since their initial release. They are a great spring. I've personally installed at least 30 sets. They are our preferred spring for LS3 applications. I use the 26926 on my more extreme applications.
Thanks,
Shane
Old 01-23-2010, 04:55 PM
david vericker's Avatar
Thanks,
Shane
I can't find the 26926 spring on the Comp Cams web sight. The only 926 spring that I found was for a Chrysler flat tappet cam. I run the 26921 springs and was interest in what Comp had to say about the 26926 springs.
Old 01-23-2010, 05:26 PM
I don't have a box here but if memory serves, they are rated as follows:
.675 max lift
approx 130# on the seat @1.835"
approx 470# open
1.100" coil bind
I'm going off of the last set I measured. I shimmed the set I used to 1.790" to get 150# on the seat (ETP LS7 w/LSL lobed cam...) rate should be about 500lb/in
We have them here:
http://www.thunderracing.com/catalog...&sid=316#P7505
Hope this helps...
Shane
Quick Reply: Comp Cam springs 26925
