TF 220 as cast w. F14, PVC ?
I am thinking about gettin the newer TF 220 as cast heads to go with my Futral F14 cam, its the regular version not the high-lift, just wondering if u guys think i will be fine as far as my PVC, BTW, the specs for the cam are 232/234 598-598 lift on a 112 lsa
a cool trick I saw on hot rod tv.take a tootsie roll leave it in the wrapper. and at room temp put it on top of the piston ,install head and valve train for that cylinder.rotate the engine 2 times remove head and tootsie.put tootsie roll in the freezer for a hour then take it out and measure with a micrometer.
Hey nasty, you will be fine with that set up as long as you dont mill the hell out of the heads and use a thin head gasket. Id call Ron at Vengeance and talk to him just to be safe though.
