224 cam
Old Jan 27, 2010 | 06:04 PM
intenseblue's Avatar
Default 224 cam
Power estimate?
SLP lid, filter, and bellows
TSP LTs and true duals
243s and TSP cam
What are the differences between the 224xe and 224r. The R looks larger in lift identical duration but it has a lower powerband as listed by TSP.
Old Jan 27, 2010 | 07:47 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Back in the day I dyno tested both camshafts next to each other. The 224R camshaft would without a doubt be my first pick between the two camshafts. You could also consider the 228R camshaft, it makes power very similar to the 224R camshaft, but makes about 5hp peak more. They both can be tuned very easily & can run a single spring if your looking to save $$$!
We can even put together a nice mail order tune for you so all you have to do is install & fire up!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jan 27, 2010 | 07:53 PM
bigc98ws6's Avatar
Default 224cam
i would think 25-30rwhp
Old Jan 27, 2010 | 08:25 PM
Soul TKR's Avatar
Definately go with the R... if anything I'd agree with Jason. You definately might wanna think bumping it up to the 228R... I would have liked to have gone that route... But i'm happy with my 224R it makes good power...
those mods I'd guess about 50-60rwhp over stock...
Old Jan 27, 2010 | 09:06 PM
What could I expect rwhp wise with Stage 1 LS6 heads and a 224 or 228?
Old Jan 27, 2010 | 09:58 PM
Quik Sand's Avatar
In a M6 car, 224 probably like 380's and probably 390's with the 228. Im not sure what all is involved with "stage 1" on those heads. With stock ls1 heads probably 370-375 with the 224 and 380-385 with the 228. Each car is different, hope this helps.
Old Jan 28, 2010 | 05:14 AM
Nitroused383's Avatar
Heres my setup: 115,000 mile ls1, unported 243's with DIY 5 angle valve job, milled .020" 11:1 compression, stainless ebay headers, LS7 clutch, home built non mandrel off road y pipe with 3.5" flowmaster merge to 3.5" cutout, LS6 intake, ported stock throttle body, slp lid, self tuned with hptuners on the street (no dyno tuning), custom bre 224 cam.
Old Jan 28, 2010 | 06:59 AM
teke184's Avatar
wow...418rwhp...
i would have said 400
i guess the compression really helps
Old Jan 28, 2010 | 09:16 AM
Quik Sand's Avatar
Wow nice numbers....you maxed the hell out of that 224
Old Jan 28, 2010 | 03:03 PM
I'm going to head back to the dyno soon. I ported up a 78mm fast intake and now its an 85mm ported fast. I will also be installing an underdrive pulley, this build was far from something I just slapped together. I'm hoping for 430rwhp and 400 rwtq. Keep in mind the LS7 clutches are proven power robbers (5-10 rwhp). There was a lot of time and detail involved but I did it all on a cheap budget, I have over 20 hours into the valve job alone.
Old Jan 28, 2010 | 05:37 PM
Redneck Z's Avatar
I made 420 rwhp with a custom 224/224 cam and mods in sig. shortly after the new motor went in.
Old Jan 28, 2010 | 06:49 PM
Thanks guys. Probably gonna do the 228r on a 112 with the Stage 1 ported heads.
Old Jan 28, 2010 | 06:53 PM
willis b otch's Avatar
I was wondering the exact same thing. but on 114lsa (I live in calif) sucks cause of smog. I wonder if I could pass with 228/114 but doubt it. less someone here actully passed with that set up & can confirm this for me
Old Jan 29, 2010 | 02:33 PM
SUG's Avatar
SUG
nice numbers
Old Jan 29, 2010 | 06:02 PM
Redneck Z's Avatar
Possible if you have a tuner who can lean you out a bit. My cam is on a 114 and it passes with the MAX allowable levels for ppm. I've heard of bigger cams passing though, with a good tune to lean it out.
Old Jan 30, 2010 | 03:19 PM
The reason I was looking at the 224xe is that I thought I could use stock LS6 springs and save some cash. I have seen nothing but one thread on this camshaft being used and the link to the dyno numbers isn't working and the power number was never mentioned.
EDIT: What should I expect from hp-wise from Stage 1 LS6 and 228R combo with TSP headers/true duals? Injectors/clutch needed?
Old Feb 15, 2010 | 11:02 AM
texas twister's Avatar
Default tsp 224r
im making 383 rwhp,375torq,,with tsp 224r,,with 243 heads,,pacesetters and
catted y
Old Feb 15, 2010 | 11:21 AM
01ssreda4's Avatar
Dont count out the TR224
