which timing chain?
Updated with link:
https://ls1tech.com/forums/sponsor-s...-new-item.html
you can actually install my cam straight up the clearance on the intake ptvc will be right around .072 with unmilled heads and stock mls gaskets...I retarded it 2* just to get a hair more clearance to around .086...so if you went with the yank set and went 1* retard it will put you right around .080 on the intake...or could go even more to 3* to gain even more...the exhaust had plently over .100 it was like .120ish
or just find a-4 -2 0 2 4 single roller...I can take some pictures of what I had to clearance if you want...
I remember seeing a good single roller adjustable on hardcore but can't remember the name...
We have the LS2 chain, the IWIS chain, the C5R chain, and the IRL chain. Listed in order of increasing price. Those are all single roller chains.
In Motion LS2 Adjustable Single-Roller Timing Set with Torrington Bearing.
NOTE: THIS SET HAS THE 1X CAM RELUCTOR!
These are available at texas-speed and perhaps other sponsors.
Is this what you're looking for?
SD7240 - single row adjustable 1x - 81.40
SD7245 - double row adjustable (with spacers) 1x 84.95
SD7640 - single row adjustable 4x 95.40
SD7645 - double row adjustable (with spacers) 4x 99.99
Charlie
A single is easier by any means, but sometimes people get the double roller. Better to use this plate and bolts than all the grinding/extra time spent.
