What would you do?
If the heads are indeed ported stock castings, the only way to know for sure what you have to work with would be to have them independently flowed. A well ported set of heads could possibly produce those numbers, but truth in advertising has long been a problem. Building the combination around too many unknown variables may only lead to disappointment down the road.
Pics of heads from OP
Sellers ad
....someone got ripped off2001 TransAm WS.6/ 440RWHP 400rwtq 30K miles, clean title, and garage kept from day one.
Direct flow intake lid/K&N filter-
FLP long tube headers w/ stainless steel high flow cast and swappable off road pipes.
ATR All stainless steel catback exhaust system. ASP underdrive pulley.
AFR 205cc Stage II heads.
Thunder racing 228/228 performance Camshaft.
Eradispeed Rotors on all 4 corners.
BMR subframes/ adj. panhard/ adj. torque arm,/LCA's/Strut tower brace
4:10 gm motive gears
Chrome 18" ZO6 rims on 275/35/18 Comp g-force TA KD's. Custom white face WS.6 gauge overlays.
Custom Billet WS.6 4 piece pedal set.
B&M Ripper shifter with custom WS.6 billet shift ****.
QTP electric cutout. Harlan shift light. embroidered head rests.
12 disc delco CD changer in the hatch.
custom cut and custom made billet WS6 hood nostril inserts and billet custom made side fender inserts. (6 pieces)
tinted windows. sides, rear and t-tops.
Interior is perfect. not a scuff. leather is perfect.
This is a must see and must drive car for the serious enthusiast.
I still have the original window sticker and all paperwork.
I have tons of pictures and will show the car to serious potential buyers.
thanks for looking!
I would say that CJ owes you some $$$$ back for misrepresentation
.... He has had it since new so he knew WTF was on it...... I HATE people like that
Past that, optimize what you have. Compression test it, re-tune it, etc.
You guys should really know the facts before just making assumptions....
Please don't make a foolish statement that the numbers are in line of a cam only car. Please show me ONE ls1 with stock heads and a 228 cam with a weak .568 lift that made 425+ rwhp.
I have NEVER seen one.Everyone has seen the cam only cars that have made 390++ hp, but you are talking about VERY VERY aggressive cam specs. (and not the best drive-ability) No 228/.568lift cam with stock heads is going to get even close to those numbers.
I chose that cam because I knew it would make good power and have great drive-ability. For me, back in the day, to be over 425+ at the wheels, in a 346ci motor, stock bottom end, to idle like stock and drive flawlessly with no hiccups was a dream come true.
This car went 310rwhp stock, with just a lid.
When Dan re-dyno's with the offroad pipes and the cutout open he will be sitting at 420-425 without blinking an eye.
The best run the car ever made was 438 under ideal conditions.
I ran SEVERAL different combos/setups on the car back in the day before leaving it the final way.
I am pretty far removed from all this as it has been several years and a baby substituted for modding for awhile, but before advising someone to scrap their heads, they need to know what there goals are.
More cubes? Stroker motor? high compression? lower compression for a power adder?? Depends on what he wants to do.
If you pull it apart, have the heads flo-ed. See the numbers, then pick your new cam. It's pretty simple if he is only looking to the 440-450 range, keeping the cubes at 346 and the bottom end completely stock. If he is only looking for another 20hp no big deal. If he wants another 40-50 sure. major changes/ head work etc need to be done if he wants to hit 475+.
If the goals are total different, then you go from there. It's really not that confusing..
Dyno queens always made me laugh. All the modded LSX cars are so sweet.
Get out to the track and see what they can do. How good of a driver are you? (especially the M6 guys)What kind of trap speed are you running......
Great comment ODAWG-- How true.. without tracking it all means nothing. Any ls1 making serious power is useless unless you can hook it up and go!!
As far as the tune goes:
The last time I had the car tuned, it ran a nice smooth 13.0 A/F ratio across the board.
I had an Autotap and used to log some data. I never saw more than 28 degrees of timing and never saw any knock at WOT.
I am not 100% if the first guy Dan took the car to made any computer modifications. I certainly am not a tuner but I even know that anything over 29 degrees doesn't usually make any more power over 26-28 degrees.
I am just glad it was cleaned up a bit and is running beautifully. That's great to see!
Also- I had lofty goals of a Procharger recently and that is why I started looking more closely at what work had already been done. My funds unfortunately can't justify a Procharger (especially since I would definitely want to put a 9" in the rear at the same time). For now, I will put in the off-road pipes, open the cutout and do a full tune until my resources warrant more.
Thanks for all of the comments and taking the time to contribute to my gearhead re-education.
Anyways that is "What I would do" and it should result in anywhere from 440-460 rwhp.
I have NEVER seen one.^^^Me neither he is making 390 about what a cam only 228 should make^^^ But when you sold it to him you told him it made 438. So which is it????Dig the hole a little deeper dude....
Dude there are 224/224 guys making 400. Is that an agressive cam?? And again what happened to little 228 "be over 425+ at the wheels" that would "idle like stock and drive flawlessly" See bold below.
First you say it made 438 with your mild little 228 and then later it takes an agressive cam to make 390 WTF. Your car never made 438,425 or even 400.
Those 390 #s are right in line for a good running stock headed 228 cam car. If you want to get in a pissing match I'll go over to the dyno section and post some up it won't be hard.
I have (nor Frost apparently) seen a 228 cam make 438 on any OEM casting.
Where are the flow sheets and 438rwhp Dynograph? I would have been proud of that and for sure kept them
Did Tony Mamo port those heads? IDK but they are not 205's like in your ad. I could be wrong but maybe way back in the day he did fool around with OEM castings but not that I know of. I can find out easily enough
Oh.. and Tony doesn't Stage his heads either....he will massage them for customers but he doesn't sell Stage 1, 1.5 etc...If he picks up 25-30 from a cutout and ditching cats I will drive wherever you are and kiss your ***. At this power level the cats are costin him 5-7 max (if not clogged) and he MIGHT pick up 5 more with a cutout unless the CB is highly restrictive which I doubt. I know because I have seen many cars dynoed back to back with only these changes.
I am usually pretty mellow and try to get along with everyone but this stinks so bad I had to jump in and call BS. I don't know dan and it sounds like he got a nice car but the performance side was toatally misrepresented.
https://ls1tech.com/forums/generatio...o-results.html
The car made 431 rwhp and 400rwtq sea corrected.
I could not be happier. Thanks to Jay @ Absolute Speed for working with me to get these heads done quickly and right to my specs.
At 550 the heads flowed 299 & at 600 they were 304!!
As people had asked, I was simply stating where the work was done, and what the numbers were. If anything I was praising the head work of Absolute Speed who IS a sponsor of this board.
I had it tuned at Dyno Pro Performance in Wauconda, Illinois and all aI can saw is WOW...
I made a best of 398.2 RWHP and 378 RWTQ SAE corrected. That was with the cutout open.
I made a best of 392.5 and 377.8 Capped.
The graphs look beautiful and smooth. It pulls hard all the way to 6600
It's the TR224 cam on the 114 LSA..
A/F made the most power right at a constant 13 to 13.5
Brian at Dyno Pro did an amazing job...
Not bad on stock heads!!! We'll see what happens with a good set of stage II's this winter!!
I'll scan the graph later tonight and get it up.....
I'm a HAPPY man today..
By the way, my best pull prior to the cam and tuning was 347 rwhp and 355 tq..
I pulled approx 50 rwhp from the cam and tuning.
THANK YOU Thunder Racing and thank you VERY MUCH BRIAN at Dyno Pro Performance!!!!!!
Best of luck!
What would you do (be specific please)?
Good Luck!
My guess is the car has Absolute Speed Stage II heads and a TR224/224 thunder cam in it right now. That's why the car put down almost the exact hp on the dyno here in Richmond
[/IMG]
You may want to invest in a stronger rear end that way you can run some D/Rs I dont care how much power you have it doesnt mean JACK without traction even on the street.
