ballancer bolt
Old Feb 16, 2010 | 03:17 PM
slolt1's Avatar
Default ballancer bolt
can it be reused or is it junk after removel
Old Feb 16, 2010 | 03:30 PM
texas twister's Avatar
its junk,,get new
Old Feb 16, 2010 | 03:37 PM
MeentSS02's Avatar
Kleeborp the Moderator™
The stock bolt is a torque-to-yield design - once they've been properly torqued down, they should not be reused. I know some people have, but it isn't the right way to do it.
ARP makes a balancer bolt that can be reused (it is not a torque-to-yield design), but costs a fair amount more than a new stock bolt from GM.
Old Feb 16, 2010 | 03:46 PM
vettenuts's Avatar
Do not throw it away it is used as part of the re-installation tightening sequence. You will first need an installation tool to push the damper back on the crank until it bottoms. The old bolt is then installed, tightened to 240 lb-ft and removed. Next you measure depth of the crank snout and if it is OK the new bolt is installed, tightened to 37 lb-ft and then rotated an additional 140 degrees.
Old Feb 16, 2010 | 05:34 PM
saloonwarrior's Avatar
Don't reuse it....they're only about $14.00 form GM.
Old Feb 17, 2010 | 09:32 AM
Jon@Texas-Speed's Avatar
I wouldn't reuse for your final assmebly but you can use it to reinstall your balancer or to turn the motor over without a balancer on it. We have both GM and ARP on the shelf. GM - $4.99, ARP - $27.99.
Jon
Old Feb 17, 2010 | 11:08 AM
fastvet's Avatar
Junk it after re-installing the pulley
Old Feb 17, 2010 | 11:09 AM
Beau@SDPC's Avatar
LS1Tech Sponsor
$4 from GM. Keep the $10 for gas.
Old Feb 17, 2010 | 11:10 AM
vettenuts's Avatar
Originally Posted by Jon@Texas-Speed
...but you can use it to reinstall your balancer ...
I would not recommend that this be done unless you mean as required by the GM procedure as opposed to pulling on the balancer?
