Head question
Old Feb 18, 2010 | 04:26 PM
jimmy92rs's Avatar
Default Head question
So i just picked up a LS1 out of a 2001 trans am with 43k on it. Ive heard that 243 casting heads are the best flowing stock head. My engine has 241 heads. How good are these heads compaired to the others? Thanks
Old Feb 18, 2010 | 05:27 PM
garygnu's Avatar
the #243 can add 20 hp to your engine.
Old Feb 18, 2010 | 05:38 PM
jimmy92rs's Avatar
so are 241s the second best behind the 243? for stock heads i mean
Old Feb 18, 2010 | 05:41 PM
02*C5's Avatar
241s are not a bad head with the right combo period. If I was going to spend money which I did on 241s I would not do it again. The 243s or 799s which are the same thing the best way to go. Invest your money wisely. Spending the same amount of money and doing the exact same thing to both 241s or 243s you will see more gains with the 243s than the 241s. Everyone has their opinion yet numbers do not lie. The other thing is if you choose to go with a light valve train using the LS6 valves you can't with the 241's because those valves are about .050" longer than what the 241 heads will allow.
Old Feb 18, 2010 | 05:46 PM
jimmy92rs's Avatar
i dont plan on changing the heads anytime soon, but i was just wondering how good the 241 heads are.
Old Feb 18, 2010 | 05:52 PM
02*C5's Avatar
If your doing that get in contact with Loyd Elliot the guy is very well respected and knows a **** load when it comes to 241 head work.
Old Feb 18, 2010 | 09:17 PM
jimmy92rs's Avatar
Right now I dont plan on doing anything to the heads. I was just wondering if they are any good for being stock
Old Feb 18, 2010 | 10:39 PM
hammertime's Avatar
All ls1 heads (241, 853, etc) in stock form are within 3-5 hp of one another. Switching one for the other is an exercise in futility, unless you have them worked over.
243 and 799 heads are LS6 castings, with notable improvements in the ports and combustion chamber. As stated above, you can expect about a 20 hp improvement in those heads, stock vs. stock. FYI, your 2001 LS1 engine comes with the LS6 intake, which is 7-10 hp increase over the '97-'00 LS1 intake.
