Going h/c have q's
Old Feb 14, 2010 | 07:46 PM
Striker289's Avatar
Default Going h/c have q's
As soon as i get my tax money i plan on treating myself with a heads and cam setup for my 2000 Trans am. So far i have:
-ls6 intake
-slp lid
-jet hot headers
-custom 3" true duals with Magnaflow mufflers
-Performabuilt stage 2 4l60e
-PI 4000 stall
-3.73 gears
So far ive been looking at getting this setup:
-Yella Terra non adjustble 1.7:1
-ls7 Lifters
-PRC Stage 2.5 5.3L Heads
-PRC Dual Springs
-Texas Speed Tsunami Cam 111 lsa
-Texas Speed Push rods 7.400"
-Rollmaster Single-roller Timing Chain
-Texas Speed ported ls6 oil pump
-255 Fuel Pump
-RaceTronix 42IB Injectors
Would this setup work well with everything else i have? Is there anything im missing? How much power should i expect?
Old Feb 14, 2010 | 08:03 PM
DVS99TRANS's Avatar
Don't assume you need 7.4 pushrods, any head/cam swap should be double checked bro. Not trying to sound snappy but I installed an MS3 with PRC 2.5 5.3s and slightly touched a few valves with 7.4s. You could save a couple bucks and get an LS2 chain also. Swapping to a fresh set of rockers is always good, but look to getting an underdrive pulley too. Powerwise, you'll easily crack 420rwhp I would think with what you have. Go for it fella, once all that snow disappears
Old Feb 14, 2010 | 08:14 PM
batboy's Avatar
That cam has a lot of intake lift. With 5.3 head and high CR, you might have clearance problems.
Old Feb 14, 2010 | 08:16 PM
Striker289's Avatar
i read about the push rods, Im planning on getting the h/c package from TSP. I guess one i get everything i need to check clearances? If they arent right ill have to order different ones.
The ls2 chain will do the job, hrm ill look into it.
I hope i make good power. I was about dead even with my buddies lt1 when he put 400 down. Now hes go about 415 and hes pulling me, I cant be having that.
Old Feb 14, 2010 | 09:08 PM
smok'nZ's Avatar
MASS seller approved
why not get a fast 92/92 while your there?
Old Feb 14, 2010 | 09:11 PM
Striker289's Avatar
cause money doesnt grow on trees. ive been saving for a year, dont make alot of money right now. i just picked up the ls6 the other month.
Old Feb 14, 2010 | 09:22 PM
hammertime's Avatar
Not sure if I read your post correctly, but the pushrod length is determined by the base circle diameter of the cam, the height of the rocker arm when installed properly (correct swipe) and the desired lifter preload. Installing shorter pushrods would not have gained you any piston to valve clearance. You either need to cut the pistons for clearance, have the valves sunk to increase clearance, or select a shorter duration cam.....
Lift is not usually the problem. When the valve is at .654 lift, the piston is no where near TDC. Duration and the Intake Centerline are usually responsible for determining PTV clearance.
Striker289, that setup should work very well. You may talk to someone at Texas Speed about what kind of clearance that setup will have. Many of these kind of cams come in closer than what is generally accepted as safe, so you might plan to cut the pistons for a little extra clearance.
Flycutting Tools - this thread is up near the top of the Internal Engine forum again.
Good Luck
Old Feb 14, 2010 | 10:18 PM
CDN01Hawk's Avatar
Since you are concerned about budget, I don't think that upgrading to the 255 fuel pump is a necessity at the power levels you are looking at - maybe someone else can confirm this - but hopefully you can save a few bucks by not having to upgrade the fuel pump at this time.
Old Feb 14, 2010 | 10:23 PM
ttranssam's Avatar
i dunno man i did the same thing but shitty home ported 241's an got 430 on a mustang dyno an the car feels great. id bet ud get me by at least 10rwhp with a fast id say for you closer to 450-460 if the stall dont soak up too much and a 90/90 wouldnt hurt either.
id say screw the rr's
and yes at least 42'ers cus i 430 put my injectors at 106% duty cycle. he prolly could have taken it up a tiny bit too
Old Feb 14, 2010 | 10:31 PM
garygnu's Avatar
measure for push rod last.you will need a BBK 85 mm TB.you might need 36 lbs injectors.you should make 420 wrhp.
Old Feb 15, 2010 | 04:34 AM
DVS99TRANS's Avatar
Exactly but when your clearance is close when you are hand cranking the motor and barely making clearance, it will get closer when you are spinning to 6400. Hence me touching a few valves, but never bent or hurt anything. Lets just say I was lucky. TSP sunk the valves on my PRC heads but it was still cutting it very close with the MS3(114LSA)<<Not the best LSA to be running on the stock motor with that cam. One thing alot of people overlook though is the fact that the LS7 lifter's lifter cup sitting around .06 different than the original stock LS1 lifters that came with the car. Hence I say check everytime because LS7 lifters are now the norm.
Old Feb 15, 2010 | 09:02 AM
shiv15's Avatar
What are the goals for your car? Why do you want 5.3/tsunami? Basically I'm asking did you just check their website once or twice and pick a package or do a lot of research into that setup? Its already been mentioned about possible ptv clearance issues.
Also, save $ and stay with stock rockers. If you're set on that cam use the $ you saved get some stg 2.5 ls6 heads over the 5.3.
Oh, and since you're concerned about a budget a cam with a high lift may not be your best option. Consider valvetrain wear and the frequency of swapping springs opposed to a lower lift setup.
Old Feb 15, 2010 | 09:25 AM
SOMbitch's Avatar
I would get a better set of heads. I am kinda disappointed in my 5.3's.......
Old Feb 15, 2010 | 10:26 AM
Striker289's Avatar
Maintence isnt a huge issue for me, I have the tools and the know how too keep up with it. Im just going based on what im getting back in taxes and what ive saved up over the last year. My motor has almost 100k on it im not skimping on rockers. I want to replace the fuel pump for the simple fact i dont want a stock pump to bite me in the *** during tuning like it did my buddy. Im not going fast, i just bought the ls6 and my throttle body is ported.
I want good power, I dont care how streetble it is. I just want it done for cruise week and i want to be able to go have good fun at the track this season.
I picked the tsunami based on the fact its been making good power, What cam would yall reccomend? And what gains would i see with the ls6 over the 5.3 heads?
Old Feb 15, 2010 | 10:33 AM
ttranssam's Avatar
sorry man but there are soooo many cams out there now.
Old Feb 15, 2010 | 10:46 AM
Striker289's Avatar
I was looking at going with a texas speed cam, since im trying to pick up one of the h/c kits, They are nicely priced. hrm decisions decisions
Old Feb 15, 2010 | 11:34 AM
wytry's Avatar
I think next time around, unless a better grind catches my eye, I'm gonna go with The Polluter cam, or get something custom spec'd. I would also ditch the RR's and put that money towards better heads. I bought the Stage 1 LS6 heads which will do me fine, but you could get the 2.5 and be really happy
Old Feb 15, 2010 | 11:57 AM
shiv15's Avatar
Call up tsp and talk to them. They will be more help with a setup
Old Feb 15, 2010 | 05:53 PM
DVS99TRANS's Avatar
You will have to call TSP for having the valves sunk so the Tsunami will fit. The lift on that cam is re-dunk-ulous.
Old Feb 15, 2010 | 07:17 PM
SOMbitch's Avatar
No phucking body listened. Have fun and **** your money away...Then post up on here how GREAT your combo is LOL. My combo should EASILY be in the 11's and it is not. When the heads come off I will get them flowed and figure out why.......Damn stock headed guys are spanking me..... And yes my bottom end is tight...
