If you've had a Comp Cams 216/220 come inside
Originally Posted by jason.sabovich
What would I need to do to make a TR220 or TR224s valvetrain sound like stock? Or is that impossible do to the extreme ramp rates of these cams (TR220 & TR224)?
I read here someone installed yella tera (sp?) rockers, and the noise was reduced a lot. Maybe this was due to the quality of the Yella ones, maybe due to the fact they are lighter, maybe both, who knows. Mods do make a difference in volume.
i just put this cam in tonight ... actually my buddys did ... heh ...
but the cam ran idled well for me with messing without anything ... it dies sometimes but overall w/o a tune ... i can feel more tq down low and even though my car shifts a 6000 i can still feel it pull
next i need headers
i can hear the lope me likey
next i need headers
216/220 will pull to around 6400rpm, great torque cam ,and has some lope. You will need tuning with an A4 , I needed misfire codes turned off and some idle corrections , just to back up somethings that some people have said or recommended I installed 02 ls6 springs and after 400 miles the springs are going into valve float at about 6000rpm for myself , 918s, sdpc springs which are manley are a much better choice.
I have a Comp 216/220 .579 .589 114LSA cam in my TA and it is a great sleeper cam. It dynod 382 and 37x through the 10 bolt. I love this cam I have over 45K miles on it with Comp 918's and it runs like a top. I've got hundreds of passes on it and drive it about 110 miles per day to and from work. I have an M6 with all the bolt-ons and stock heads. I have ran a best of 12.19 @ 112.7x with it. It normally MPH's in the 113's and has bested a 115 MPH on street tires. It peaks @ 6400 RPM.
I bought this cam b/c I was told it would have perfect drivability and it does. I crank my car up cold and drive, no wait.
There are a lot better cams to choose from for performance, but if you want perfect drivability this cam is great, drives like a stock cam.
Yes it was a custom grind that JPR had for a customer that backed out of it, I too was like 579 589 what the heck was that but I got the yellow cam card here and thats what it says, when I first put it in it did have the sewing machine sound, but it's quieted down over the 45K miles that are on the 918s.
I bought it for 200 bucks new so I didn't complain. It is a VERY high lift cam but works great, daily driven over 100+ miles a day It propelled my 3750 Raceweight TA to a 12.19
The most common 216/220 I've seen are like 216/220 .54x .54x 114, they normally dyno'd about 365-375 with all the boltons on stock heads. I would like a see a before and after dyno of a 216/220 after someone put on a set of stage II heads and re-dyno'd.
