arp rod bolt torque
Old May 4, 2010 | 10:58 AM
vettenuts's Avatar
Originally Posted by cutlass_455
To properly install rod bolts you should be measuring stretch, and not torqueing anyways.
That's what I thought and what ARP recommends.
Old May 4, 2010 | 11:03 AM
KCS's Avatar
KCS
Moderator
Even with a torque wrench, you will still get pretty close to the target preload. Knocking in 10 minutes sounds like something else went wrong, like forgetting to reinstall the pickup tube, lol.
Bad Notch's Avatar
My ARP Waveloc bolts came with a paper that said 45ft lbs as well.
Old Aug 18, 2011 | 08:02 PM
twgoodspeed's Avatar
so my worry is how do i know what bolt i bought now, i bought these a couple years ago and now im worried, i torqued them to 45 and backed them off did this 3 times
Old Aug 19, 2011 | 11:55 AM
chrisfrost's Avatar
The only way to be 100% sure is if You had measured them before torq them and written down every bolts length and measure them now and per instructions if any bolt has stretched .001 , replace that bolt meaning the set unless anyone knows where to obtain single ARP fasteners .
Old Apr 15, 2015 | 06:56 PM
MillsMotorvation's Avatar
Originally Posted by Dickie-311
OK ARP told me the part number i have 134-6006 TQ to 45ft ... the other p/n they list is 234-6301 TQ TO 40 FTLBS.. so i'm allset
Great info on rods bolts thanks!
Old Apr 16, 2015 | 01:35 PM
KCS's Avatar
KCS
Moderator
That info is wrong:
134-6006
234-6301
If you need kit instructions, to include torque values, all you have to do is go to arp-bolts.com and enter in the PN for your kit and it gives you the instructions. It's very easy and very simple.
Old Aug 4, 2015 | 07:44 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
How do you re-size the connecting rod? What is the precedure for that?
Old Aug 4, 2015 | 11:18 AM
KCS's Avatar
KCS
Moderator
You just hone it out ~.002" larger and use a bearing meant for the larger bore.
Old Aug 6, 2015 | 06:56 AM
ChevyChad's Avatar
So, this is not a simple DIY project then. It involves machine shop labor and new bearings. No wonder so many people have mixed results with this mod.. So by the time you account for the new bolts, machine shop labor, trip expenses to and from the machine shop, new bearings, etc. How much are you saving vs buying new rods that already have ARP bolts included?
Old Aug 6, 2015 | 08:02 AM
KCS's Avatar
KCS
Moderator
No, it has to go to a machine shop.
It's cheaper than using an aftermarket rod. The cheapest option I know of is a Scat I Beam and they only have a press fit pin if you stay with the stock size .943" pin. With the press fit pin, you're still having to use a machine shop to hang the rods and pistons.
Scat also has the same I Beam rods with a .927" pin, but the pistons are typically more expensive once you go that route.
Old Aug 6, 2015 | 08:46 AM
  #32
ChevyChad's Avatar
Good to know. Thanks
