arp rod bolt torque
Old Feb 20, 2010 | 05:49 PM
slolt1's Avatar
Default arp rod bolt torque
what is everyone torquen the arp rod bolta to on the instructions it says 40 that just seems to light
Old Feb 20, 2010 | 05:54 PM
Darkman's Avatar
I don't know about ARP. As a point of reference GM's current spec for OEM bolt is:
Tighten the connecting rod bolts a first pass to 20 N.m (15 lb ft).
Tighten the connecting rod bolts a final pass to 85 degrees using the J 45059 Angle Meter.
Katech's call for 50 ft lbs. but the last time I looked they TS was 260K and ARP was only 200K.
Old Feb 20, 2010 | 07:05 PM
xpndbl3's Avatar
40 is what I used no problems. I find it funny that people state that katech don't need rod resizing yet they require a higher torque spec than arp. You always see the posts that state ARP bolts will require rod resizing but yet the katechs need 10 more ft/lbs of torque, so wouldn't that stretch them out even more ?
Old Feb 20, 2010 | 07:08 PM
squirlNUTZ's Avatar
depend on type of metal or steel. There are manym kinds or mixtures of both
Old Feb 21, 2010 | 05:53 PM
Dickie-311's Avatar
the paper that came with my rod bolts said 45ft lbs
Old Feb 21, 2010 | 07:02 PM
butler's Avatar
depends on whether it has aftermarket rods in it or not. My 7/16 rod bolts had more torque on them.
Old Feb 21, 2010 | 09:46 PM
slolt1's Avatar
the paper that came with my arp rod bolts said 40
Old Feb 22, 2010 | 04:11 AM
Dickie-311's Avatar
stock rods... paper said 45 ...going to call ARP TODAY
Old Feb 22, 2010 | 06:14 AM
butler's Avatar
understood
Old Feb 22, 2010 | 06:22 AM
blue98Z's Avatar
IIRC my ARP sheet said 40 back off, retorque to 40, back off then a final tq to 40ftlbs to properly stretch the bolt. Thats been nearly 2yrs ago and no issues so far with several passes.
Old Feb 22, 2010 | 08:34 AM
slolt1's Avatar
thats exactly what my papersaid blue98z
this is for the factory rods also
dickie-311 please let me know what arp tells you
Old Feb 22, 2010 | 11:13 AM
Dickie-311's Avatar
OK ARP told me the part number i have 134-6006 TQ to 45ft ... the other p/n they list is 234-6301 TQ TO 40 FTLBS.. so i'm allset
Old Feb 22, 2010 | 02:17 PM
01ssreda4's Avatar
At what point do you think you are smarter about fasteners then ARP??? Just follow the instructions and go on about your business.
Old Feb 24, 2010 | 08:26 AM
Dickie-311's Avatar
post up what part number ARP rod bolts you purchased and TQ SPEC'S
Old Feb 24, 2010 | 11:22 AM
Convette's Avatar
anyone know a first hand difference between the two other than about $25?
Old Feb 24, 2010 | 02:35 PM
01ssreda4's Avatar
strength
Old May 4, 2010 | 06:57 AM
boxmod's Avatar
yea so i did this. called ARP. checked, triple checked his procedure and trq settings. stock rods. rod knock in 10 minutes.
thank arp.
Old May 4, 2010 | 09:33 AM
KCS's Avatar
KCS
Moderator
thank arp.
Did you happen to resize the rods?
Old May 4, 2010 | 10:05 AM
cutlass_455's Avatar
To properly install rod bolts you should be measuring stretch, and not torqueing anyways.
Old May 4, 2010 | 10:13 AM
KCS's Avatar
KCS
Moderator
One is ARP's 8740 steel, the other is their "ARP 2000". I found this on their website:
19. What and how exactly is ARP2000 does it compare to 8740 and 4340?
ARP2000 is a heavily alloyed martensitic quench and temper steel, initially developed for use in steam power plants. As such it has excellent stability at high temperatures. But most important, ARP research discovered that in addition to temperature stability it has excellent notch toughness in the higher strength ranges and is alloyed to be tempered to Rc44/47. 8740 and 4340 can be tempered to the same hardness. But, the tempering temperature would yield material in the “temper brittle zone” (between 500° and 700°F), producing significant notch sensitivity. ARP2000 is tempered above that temperature range and has a strength between 200,000 and 220,000 psi.
20. How does L19 compare to ARP2000?
L19 differs from ARP2000 in that it is a vacuum melted alloyed steel with sufficient chromium and carbon to achieve high hardness (but below the level of a stainless steel). L19 is air-cooled from the hardening temperature in a way that does not require an oil quench to achieve full hardness and is tempered to assure full conversion to martensite between 1025°F and 1075˚F. L19 is a proprietary material capable of achieving strengths of 220,000/230,000 or 260,000/270,000 psi as may be required. Both L19 and ARP2000 steels are modified bcc (martensite) at room temperature. L19 has the same advantage as ARP2000 in that a high strength is obtained at a high tempering temperature. This alloy is easily contaminated and requires special handling.
L19 is the stuff 2000hp Outlaw cars use for headstuds.
