Help deciding between lm7/lq4 for 240sx
My budget is about $3500 +/- $200
I will put away $1500 for the t56.
$300 - GTO oil pan
As for a cam, I was looking at 228r - $450 (cam, pushrods, springs)
I already have a FAST 78mm intake manifold also.
I also have some 241 heads I could toss on but I don't think they would give an improvement. Would probably get the stock 5.3's ported or something later on.
Everything else is up in the air. What i want from this car is a fun, fast, car that can keep up with vette's and other v8's on the street and track. I'm looking for mid to low 11's in the quarter mile NA and 10's on spray (100 or 150). I figure 400WHP NA should put me in that area. The car will be running a 3.90 rear end.
One more question is the front accessories, I have the ability to make brackets and whatnot but will I need to buy the F-body setup? I will be running PS but no AC.
I am not too worried about the extra weight of the iron block over the aluminum of the ls1 because this car has no interior and should still be under 28--lbs full weight.
I would like to go with the larger cube lq4 but the very cheap cost and availability of the lm7 is very appealing.
So what setup would place me at my goal? Any tips or insight?
Thank you.
Check a nationwide junkyard site. You might have to ship, or if you don't mind, take a trip, but they're out there. Just gotta look and be patient.
I actually just came across a 98' ls1 with a rod knock for $400. I figure I can tear that down, do bearings, rings, and gaskets. Then along with the cam and FAST manifold It should put me right at 400.
What do you think? any insight?
