Add injectors?
Old Feb 25, 2010 | 06:41 PM
Bjorne043's Avatar
Default Add injectors?
I just received my TSP H/C package in the mail. I went with the prc ls6 stage 2.5 heads and the 228r cam. 7.4 pushrods and an ls2 timing chain. I'm running an LS6 intake currently.
What do I do with injectors? Do I stick with the stock 28# injectors or do I upgrade them? If so, what size? Or do I wait to do the injectors until I add a FAST intake?
Old Feb 25, 2010 | 07:08 PM
00MaroonZ28's Avatar
Upgrade to the 42 lb injectors.
Old Feb 25, 2010 | 08:09 PM
01ssreda4's Avatar
Run a minimum of the SVO 30s. Your stockers arent up to the task in any way shape or form
Old Feb 25, 2010 | 10:13 PM
NinetynineSS's Avatar
That looks close to what I'm building, and about "everyone" said go with 42's. I'm thinking that must be the way to go, plus, you could just move 'em to the FAST later!
Old Feb 26, 2010 | 12:16 AM
Bjorne043's Avatar
^^Well played sir! Now on the hunt!
Old Feb 26, 2010 | 06:41 AM
garygnu's Avatar
where are you going to dyno it at ?talk to the people at HI-TECH MOTORSPORT in Elk River about injector size.will your fuel pump flow enough for your motor upgrade?
Old Feb 26, 2010 | 09:16 AM
jkkaz's Avatar
I have a similar set up but with the 5.3 stage 2.5. I'm installing a fuel pressure guage along with a set of after market fuel rails. Also, I have a wideband 02 sensor. What I was planning on doing was watching the injector duty cycle and fuel pressure to make sure I'm not losing pressure and maxing out the duty cycle. BTW I also have HP tuners. This is turning out to get more and more expensive at every turn.
Old Feb 26, 2010 | 09:23 AM
PAULZ98SS's Avatar
i have an off subject question, sorry. how much was the shipping on that? and taxes? im trying to budget build. been doing research and 42# injectors work the best with a tune.
Old Feb 26, 2010 | 11:12 AM
Bjorne043's Avatar
shipping was around 50 dollars and taxes were free. If you are ordering from out of state there are no taxes.
Old Feb 26, 2010 | 12:07 PM
PAULZ98SS's Avatar
sweet thanks!
Old Feb 27, 2010 | 05:49 AM
Listen, P.M. me and I'll give you the info you'll need, especially the tune. You're in my neck of the woods and I'll be able to help and recommend you where to go. I might even have a F.A.S.T intake available soon. You on MNGMP.ORG at all?
Old Feb 27, 2010 | 09:43 AM
wytry's Avatar
I've got a slightly larger cam than you and my tuner told me that I would likely not need injectors ...so I went out and bought flow-matched 42#er's from FIC
Old Feb 27, 2010 | 09:56 AM
blue98Z's Avatar
Your gonna need at the very least some 36#rs, but 42's would leave some room for future upgrades. This: http://www.rceng.com/technical.aspx will tell you what you need for sure as far as injectors. Your setup will probably get you some where in the 430hp range so that would be a good guesstimate for the equation. I know every car responds differently to mods so thats why I say guesstimate lol
Old Feb 27, 2010 | 10:48 AM
SOMbitch's Avatar
I would be very surprised if they will be over 80% duty cycle. Just get it tuned and find out and only spend the $$$$ if you have to....
Old Feb 27, 2010 | 10:54 AM
blue98Z's Avatar
And just for reference I'm running cam only and my duty cycle is at 90% which is more than it should be but ok for me at the moment til I figure out what I'm gonna do next.
